Car shaking very hard
Old Mar 29, 2003 | 12:46 AM
juani's Avatar
Rockin' VK56!!
Tonight i was on my way to pick up my friend over an hour driving distance. I had no problem when i was going there, but when i was coming back, I felt huge shaking on my car. First i thought it was just road, but whenever i go for acceleration, the car shakes. Especially on 55-65 mph, it shakes really hard that it makes me release the acceleration pedal. I put the gear on nutural and rev up to 6000, but it didn't shake the car. please help me~!
thanks.
-john
Old Mar 29, 2003 | 12:59 AM
Nismo's Avatar
any ecu codes?
Old Mar 29, 2003 | 02:00 AM
TurDz's Avatar
Since your sig says that you're looking for 5-speed conv. parts, I assume you're an auto.
And since you tried disengaging the tranny and you didn't feel any violent shaking, it probably has something to do with the tranny. Just a little common sense reasoning.
Also, try taking it for a drive again in your residential area. Post back any more details so you can get more thorough help. Such as what speeds the shaking happens, etc. Also, maybe a odometer reading would help too. Hopefully it's not too bad.
Old Mar 29, 2003 | 07:30 AM
fisher01's Avatar
My first impression was tires but since you put the car in neutral and it didn't shake I would rule out the tires. I to am thinking transmission related, maybe a drive axle? Does the car make any noise when making a turn at slow speeds to the right or left?
Old Mar 29, 2003 | 03:01 PM
Nismo's Avatar
while driving when the shaking occurs, what does the rpm look like? does it dip to low rpms or does it stay normal? im saying that because on a car that we used to have, it use to bog down when you step on the gas because the MAF sensor was dead so the engine shook until it bog itself down and shut off.
Old Mar 29, 2003 | 03:56 PM
juani's Avatar
Rockin' VK56!!
My odometer reading is currently at 58300 miles.
it only shakes hard when it's speed is at about 55 mph ~ 65 mph, when it's lower or higher speed than that, it shakes less. and the rpm is just normal when car shakes. And when i turn my wheel all the way to left or right with slow speed, I hear some kind of metal twisting like sound. Yes, i drive automatic.
Thank you for your help, i really appreciate it
-john
Old Mar 29, 2003 | 05:36 PM
Nismo's Avatar
-john
So far the only thing I can think of is that one of your motor/transmission mounts are loose. go check those out for now. It also wont hurt to look around at your suspension components/wheels to make shure those are not loose too
Old Mar 29, 2003 | 07:26 PM
Dasyce's Avatar
couldn't it be a bent rim?
Old Mar 30, 2003 | 12:23 PM
SmackDown85
possibly, but doubtful...i had a bent rim on my max and got brand new 18s and my car still shakes, i have NO FREAKING CLUE what it is
its not the tires, nothing to do with balancing either..only thing i can think is POSSIBLY the transmission or a suspension part..
my car only shakes when im going over 50+ mph, and the faster i go, the worse it is..PLEASE HELP ME TOO GUYS!!
Old Mar 30, 2003 | 12:35 PM
Lime's Avatar
Uh. Yeah. Revving in neutral won't make a difference if it is a tire problem. Obviously it's not a motor problem, but that DOES NOT rule out tires since the tires wouldn't be moving if the car was stationary in N. It could be a wheel/tire/bearing problem. If the problem only occurs when the car is moving, then my guess is it is suspension or something tying into the steering.
Old Mar 30, 2003 | 01:00 PM
iansw's Avatar
If it's more noticable by far under accelleration, it's your inboard Driver's or Passenger side CV Joint.
Trust me - I spent 4 months and alot of time replacing tires, getting wheels balanced, checking brakes and rotors and engine - etc, etc...
Some people may tell you that the CV Joint would click when turning. This isn't true. Only the Outboard one clicks when turning.....the Inboard causes massive vibraiton under accelleration. Also makes a very dull "whumpwhumpwhump" sound (almost sounds like wind noise in rythm with the wheels).
For me also, it was worst at 55-65, when accellerating mostly, and a little when cruising.
What springs do you have?
Anyway - call Marti at Raxles.com - awesome guy - he'll hook you up with a nice axle.
Old Mar 30, 2003 | 01:17 PM
FLO_BOY's Avatar
A simple thing to check...
...would be the wheel weights used to balance your rims.
check it out -- could be the simple answer here (could be something
worse, but, let's eliminate the easy one first!)
FLO_BOY
Old Mar 30, 2003 | 01:41 PM
iansw's Avatar
Re: A simple thing to check...
FLO_BOY
I suppose that's an option, but wheel balancing being off at freeway speeds is very noticable even in Nuetral and coasting.....he said it doesn't shake in neutral - I'm assuming he means on the freeway, coasting.
Is that what you meant, maxima8624?
Old Mar 30, 2003 | 02:10 PM
gtr_rider's Avatar
192.168.1.1
Were you playing "Luke's freak show" ?
Old Mar 30, 2003 | 02:15 PM
juani's Avatar
Rockin' VK56!!
iansw- yes. when coasting, i only can feel little shaking at 55~65 mph, but when i'm giving acceleration at that speed, it's shaking really hard.
but my friends who were sitting on the back seat didn't feel any shakings at all. i guess i only can feel shakings on the front seats.
Old Mar 30, 2003 | 02:34 PM
iansw's Avatar
Yep - my friend in the back seat said they felt it a little, but not alot. But my friend in the front seat was telling me to pull over and call a tow truck it was shaking so hard.
It's your CV Joint....I'm sure of it. But just to be sure, have a mechanic look at it if you want to be really sure.
Old Mar 31, 2003 | 12:25 AM
juani's Avatar
Rockin' VK56!!
thanks iansw and others for helpful thoughts
carguy96
20
Feb 6, 2021 06:21 AM
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
jhontelj
Aug 17, 2015 04:07 AM
Wolvee
Aug 11, 2015 12:24 PM
