Chain or belts?
Old Mar 31, 2003 | 09:31 AM
RAZER's Avatar
Chain or belts?
Do we have timing chains or timing belts. If we have belts every how often should i change it. Also when i start my car i hear a squealing noise at crancking and it longer to crank when it starts. Can someone please help me...
Old Mar 31, 2003 | 09:34 AM
pocketrocket's Avatar
Timing chain. Does not require replacement or maintenance under normal circumstances.
Squealing of the starter motor, sounds like the starter motor is stuck after you release the key? Like a donkey whine? If so, grease has dried out inside. Check out www.motorvate.ca where they have a good write-up on repacking the grease in the starter motor (or you can replace the starter motor before its untimely demise)
Edit: If the squeal is present only during cold weather, then it's most likely the grease. Shut your engine off after driving for a while, and re-start. If no squeal, most likely grease.
Old Mar 31, 2003 | 10:08 AM
waveridr85's Avatar
i am getting a cel w/ the knock sensor code, i wass told it could bhe my timing, is it possible the my timing belt is too advanced?
05' MaximaMan
Oct 8, 2017 06:36 PM
markevans999
Oct 25, 2015 08:27 AM
kjlouis
Oct 3, 2015 05:29 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
