How to make shifts in auto smoother....?
Old Apr 2, 2003 | 10:26 AM
madmax97's Avatar
It seems my car doesnt shift nice and smooth from gear to gear, what can i do to make shift more fluent and better. thanks Its an auto.
Old Apr 2, 2003 | 10:28 AM
Zirafa's Avatar
-flush tranny
-switch to synthetic ATF
Old Apr 2, 2003 | 11:54 AM
Jepht20's Avatar
Custom User Title...
Originally posted by Zirafa
-flush tranny
Old Apr 2, 2003 | 11:58 AM
happyricefob's Avatar
V^___^V
yea... same with my car when it's not well warmed up =( but u can try to clean ur TB, clean/oil ur filter if it's dirty... mods like cold air intake will help u have better shift, or u can get a S-AFC and control ur fuel ratio manually... etc...
Old Apr 2, 2003 | 02:32 PM
ch13f's Avatar
How would changing an air filter/cleaning tb make your shifts smoother? Those two things would probably cause your car to idle more smoothly but...
Old Apr 2, 2003 | 04:02 PM
nadir_s's Avatar
vicodin ... gift of life
nah, that will only improve acceleration, and like you said, idling.
Old Apr 2, 2003 | 06:20 PM
waveridr85's Avatar
how to flush the tranny?
Old Apr 2, 2003 | 06:46 PM
96BLUMAX's Avatar
Have someone do it or drain it from the plug and refill.
Old Apr 3, 2003 | 08:06 AM
genepool's Avatar
Short Version:
Remove the return line from the tranny, start the car, and the tranny oil will spout from that line. After removing a certain amount, like a gallon, put in the same amount of new oil that you removed. Continue process until you see the bright red oil coming out of the return line.
Old Apr 3, 2003 | 01:17 PM
joew's Avatar
I have the same problem and very much would like to improve a smoother gear shift. Someone mentioned, by changing the tranny oil, it will not do the job.
I had a mazda with the same problem. I had my trans oil changed. It did not work.
Does anyone have experiences in solution this problem.
Old Apr 3, 2003 | 02:05 PM
Eric L.'s Avatar
I flushed my transmission and refilled with Redline D4 ATF using the T-tech service at Jiffy Lube. Pretty expensive. $80 for the service and $100 for the fluid (self supplied).
However, my transmission shifts perfect right now. Still not Toyota smooth, but hey, its a Nissan, what can I expect.
Old Apr 3, 2003 | 03:28 PM
ZuMBLe's Avatar
Okay, I'm sure lots of other people want to do this too.. So..
WHAT THE HELL ARE YOU TALKING ABOUT?? He wants to know how to make his tranny shift better! Will leaning out the air fuel mixture do that?? NO!
Old Apr 21, 2003 | 07:16 PM
Maxima99SE's Avatar
will fly for food
will the car needing an A/T flush cause it to not shift into O/D?
Old Apr 21, 2003 | 08:33 PM
s0ber's Avatar
is it easy to flush the tranny out and about how much would that synthetic atf cost me and how much would i need? :P I dont want to pay someone for something that could be like an oil change.. aint there a filter to change as well?
Old Apr 21, 2003 | 08:37 PM
tampamax's Avatar
Re: How to make shifts in auto smoother....?
Lucas Oil Products Currently rollin on the original tranny in my 91 celica with 250K+. It may be ugly, but the a/c is ice cold and it get 40 miles to the gallon.
Old Apr 21, 2003 | 08:46 PM
imstuckherenow's Avatar
vb mod maybe?
Old Apr 21, 2003 | 08:47 PM
tampamax's Avatar
To answer your question, no. The od uses a clamp of sorts it does not actually have gears or use reaction plates or clutches(in the conventional sense). You should not have to worry about your tranny if the od doesn't work. Eventually yes, right now no. Just don't try to use the od and when you feel one of the other gears slipping then take care of everything. If i'm wrong then someone please correct me, but your tranny will not go any faster because your od is slipping. It will have everything to do with your driving habits.
Old Apr 21, 2003 | 10:24 PM
tampamax's Avatar
Originally posted by imstuckherenow
vb mod maybe?
Just the opposite....the vb mod produces firmer quicker shifts. He's looking for softer more fluent shifts.
Old Apr 22, 2003 | 04:49 AM
mrmaxima97's Avatar
Fixed my problem
I had this problem on mine, the shift from 1st to 2nd was extremely rough. To the point where I would slow the car down when it shifted.
I did some work this weekend and the car is running better then new. We upgraded the battery grounding, to 4, and ran an extra grounding.
WOW, what a difference. When the car shifts now you don't even notice. When I am WOT, it is a smoother shift through all the gears even at high RPMs. My car drives like it should again.
Anyways, I know everyone is going to say that the grounding did not do anything, but the difference can be felt. I am not sure if it was just the disconnecting of the negative from the battery for about an hour or if the actual upgrade of the cable helped, but its amazing.
My little story.
Old Apr 23, 2003 | 12:20 PM
Lizardking's Avatar
Fixed mine too
Just to pass this along...
I had a tranny flush done in january, then shortly after i noticed harder shifts, especially from 1st>2nd, 2nd>3rd... took it in to get looked at and they said nothing was wrong, after reading this post i unhooked my battery for a few hours, hooked it back up and went for a nice long drive, and my tranny was back to shifting nice and smooth. might as well try it...
Chris
Old Apr 23, 2003 | 01:10 PM
Bgohan's Avatar
Changing the above along with changing dirty PCV valve and old plugs will improve performance and vaccuum, and therefore can make for smoother auto shifting. Try varying your throttle slightly during a shift and see what happens. The same thing is going on if your engine is not running right.
Old Apr 24, 2003 | 11:33 AM
joew's Avatar
Re: Fixed my problem
how did you do it?
Old Apr 24, 2003 | 11:43 AM
Maxima99SE's Avatar
will fly for food
tampamax, you cant see my quote anymore but I found out your answer is right... my transmission wouldnt shift into O/D because of an automatic transmission temperature control sensor... thanks for answering my question
220k+ A32
Sep 11, 2015 02:18 AM
Maxboy23
Sep 9, 2015 10:37 AM
Adoubi21
Dyno Discussion and Slips
Sep 7, 2015 09:34 AM
Maxboy23
Sep 4, 2015 06:04 PM
