Lights: Important Need Help
Old Apr 2, 2003 | 09:06 PM
APER5's Avatar
HI, MY SIDE MARKERS, THE LIGHTS NEXT TO THE SIGNALS (front), AND THE BLUE LED WINDSHIELD NOZZLES THAT ARE WIRED TO THE SIDE MARKERS.....ALLL WENT OUT.....ANY SUGGESTIONS AS TO WHAT THE PROBLEM MIGHT BE......IT JUST HAPPENED OUT OF NO WHERE I NOTICED
IM HOPING IF THE CAR RESTS ALL NIGHT IT'LL BE ORIGHT IN THE MORNING LOLOL....NO REALLY ANY SUGGESTIONS.......HELPPPPPPPPPPPPPPPPPPPPPPPPPPPPP PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP
Old Apr 2, 2003 | 09:10 PM
Odie96's Avatar
Re: Lights: Important Need Help
Maybe a fuse or a short somewhere
Old Apr 3, 2003 | 12:47 AM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
It's the LED nozzles, the max has a self-terminating system where if it feels it's too ricey, it will self-inflict damage to itself. It's actually a from of automotive suicide. Your car is crying out for help.
But seriously, when you say side markers, do you mean the corner lights (next to the headlights) or the lights that are part of the turn signal assembly (the ones that come on when you turn your parking lights on)?
Any suggestions.....first, turn off the caps lock (hahah). Then, check the fuses for the lights, and if it's blown, replace it. But before you turn the lights back on, check the connection where the wires for the nozzles meet the wires for the sidemarkers. That is most likely the problem. Have you recently wired them up? Or have the nozzles been there for a while?
Replace the fuse, and unhook the nozzle wires from the side marker wires. Now test it. Everything ok? There's your problem. Either tap it into a different wire, or (if you want to be super safe) wire it to the battery, and then to a switch inside the cabin.
Old Apr 3, 2003 | 05:36 AM
njmaxseltd's Avatar
Re: Re: Lights: Important Need Help
Old Apr 3, 2003 | 05:50 AM
maxperformance's Avatar
Re: Re: Re: Lights: Important Need Help
try checking yuour fuse, i was changing my taillight bulb because it wernt out and the fuse just blew. it could be as easy as that.
Old Apr 3, 2003 | 07:09 AM
phenryiv1's Avatar
Mod her. Ate her.
At first I thought that you were serious about that!
Chech fuses and look for potential shorts. Did you insulate all of your splices?
Old Apr 7, 2003 | 07:13 PM
APER5's Avatar
update
yea just as a reply..this is first time since i posted the original post..it was so stupid it was only a fuse...no extras so i took the 7.5a fuse(mini)...from the airconditioner just for time being so i dont get pulled over...waah laahh i saw the "light"...next day got some extra 7.5a fuses (mini) and put the one i took out for the air conditioner and it was all done....thanx for the advice guys all though it was of no help cuz i never checked it until now but however i fixed it on my own...AND NO LED NOZZLES ARE NOT RICEEEEEEEEEEEEEE BUT HEY TO EACH HIS OWN
________________________________________
18" CHROME KMC, FALKEN ZENIS TIRES, BRIGHT CORNERS, CLEAR SIGS, 20% TINTS, MS EXHAUST, EIBACH, KYBAGX, 10DISC CDCHANGER...CLEAR REAR SIGNALS....BOO YAHH
Mar 12, 2020 12:06 AM
97_GXE
Sep 15, 2015 06:47 AM
carid
Sep 9, 2015 05:06 AM
crazyespn
Sep 3, 2015 01:30 PM
