Ignition Coils Replacement Question
Old Apr 2, 2003 | 11:34 PM
vipervadim's Avatar
I like Maximas
Ok so i have a beautiful 99 SE and i probably have a faulty ignition coil since i got a Cylinder 4 Misfire ECU code.
now i cruised over to the consumer nissan parts website. and i found the coils replacement page and here is what it lists:
DOHC Hanshin LH 1 of 3
Ignition Coil 22448-31U06 1
DOHC Hanshin RH 1 of 3
Ignition Coil 22448-31U01 1
DOHC Mitsubishi LH 1 of 3
Ignition Coil 22448-31U16 1
DOHC Mitsubishi RH 1 of 3
Ignition Coil 22448-31U11 1
Now which are the better coils? the Hanshin or the Mitsubishi?
Also which are the LH coils -- the front (under plastic spark plug cover) coils or the back (closer to firewall)? i've been wondering about this for a while and i'm sure other owners can benefit from this as well
thanks!
-Vadim
Old Apr 3, 2003 | 05:35 AM
RobbV's Avatar
Re: Ignition Coils Replacement Question
Just replaced a second coil in my 99 SE yesterday. I had the Hanshin coils and just replaced tht part...not sure if that was dumb or not. Anyway, I replaced the #6 cylinder ignition coil with the P#22448-31U06-1 part. This should be the same one you are looking for, as the "even" numbered cylinders are the ones under the plastic cover.
The "left side" coils are under the plastic cover & the "right side" are therefore closer to the firewall.
Hope this helps.
Old Apr 3, 2003 | 04:05 PM
Mishmosh's Avatar
Re: Re: Ignition Coils Replacement Question
Why are 99 coil packs failing so often? What brand comes stock, Haishin or Mitsu? Also, are you all replacing these out of pocket or by Nissan as part of a TSB?
Old Apr 3, 2003 | 06:01 PM
infinitiblast's Avatar
haha thats funny I have a 99sel and just ordered three right coil packs. Two mecahnics wanted 100 bucks just to read the codes, so I cant see which cyl is misfiring so..I will replace the back three and hope for the best. Autozone could only read a p1320 code which is ignition primary failure.
Old Apr 3, 2003 | 06:07 PM
redmaxpa007's Avatar
i SeE what you did therE
wow... i have been hearing of 99 coils failing but i never paid any attention to it before..
man.. i am getting worried now..
Old Apr 4, 2003 | 05:50 AM
vipervadim's Avatar
I like Maximas
bump
Old Apr 4, 2003 | 02:21 PM
My car's idle stutters by about 100 RPM at idle and I feel a small jerk...
Also I get a quiet click sometimes when I floor the car.
Does this sounds like a faulty ignition coil?
Dave
rbuswell
Nov 17, 2016 04:54 AM
vingodine
45
May 21, 2016 12:46 PM
kenc15
Sep 25, 2015 06:38 AM
Maxboy23
Aug 21, 2015 11:02 AM
maxima297
Aug 3, 2015 12:50 PM
