Finished conversion, now how about some reverse lights?
Originally posted by Mad Dhan
it was plug and play for me, no cutting, tapping into anything.
Umm.... we are not talking about the same things.
I mean coversion like 5 speed conversion.
my mistake, your fault. I dont know the answer to that one, sorry
My fault?
Please reread the first post.
"Where do I tap the harness from the tranny into. Which wire(s) go where. Anybody?"
Tranny...Not tails.....
Originally posted by 96shogunmax
My fault?
My fault?
maybe this will help you out, its from my hayes manual:
http://home.socal.rr.com/dhan/DSC02410.JPG
twas a joke.......nm
Thanks...anybody else know how?
Originally posted by Cumalittle
On this diagram , I have two harnesses that have 8 plugins, 7 which are used. Like above, but I have two of them . One has a purple and pink color wire in it and the other is just then normal colors. But on the diagram it shows the thing that you push for the release to be on top. That makes the blank wire on the bottom right. Mine is not like that. The blank is on another side. Which harness do I need to tie into of the two and which wires are what? Any colors ?
u are correct...just that i was too lazy to make that change...the picture u see is actually looking at the auto tranny...from auto tranny it would be terminal 3 and 5 when u put it on reverse...so if u reverse it and look at the car...it in turn would be terminal 6 and 7...ok..looking at the harness from the car...tap into the top row first terminal from ur rite...then tap into the 2nd terminal from ur rite...in other words...it's on the opposite end of the terminal not being used...
You wouldnt happen to know the colors would you. Because I have two plugins that have 7 spots in them that are not being used from the auto.
I give up. I got the harness from the auto and everything. Did it just like you said. Didnt work. Any fuses that might be blown? Tried it many many times.
Manual tranny colors - blue then the other is blue/pink
auto harness - yellow and white
correct me if I am wrong
then it's trouble shooting time...put ur 5spd in reverse...then take an vom and check continuity w/ the two terminal from the tranny...if u get continuity then ur park/neutral switch is good from the tranny...the other step is to get a piece of wire...short out the two terminal from the car's harness..ur reverse light should light up...if it doesn't...then 4 possible trouble...wrong terminal...car harness trouble...or bulbs are no good...possible fuse...
fastcarny
Oct 6, 2015 10:42 AM
Hdnseek
Sep 9, 2015 05:55 AM
Maxima30
Sep 7, 2015 06:13 PM
