Cheap Mods
Cheap Mods
After spending like $2300 on mods in the last 2 weeks I am looking on getting some cheap stuff. Simple thing like lil light bulbs to replace the alarm and give the car a bit more custon look, any ideas? thanks guys
Re: Cheap Mods
17" rims
hankook tires
cold air intake
K&N filter
2 rocky fosgate subs
bandpass box
wires & fuses
500 watt amp
g-tech competition meter
headlight bulbs
wired switch in console to turn on amp
y-pipe
high flow cat
thingy to get the rca cables from bose speakers
02 sensors
caliper paint
and a fart pipe
you can see the rims an calipers on my homepage
hankook tires
cold air intake
K&N filter
bandpass box
wires & fuses
500 watt amp
headlight bulbs
y-pipe
high flow cat
02 sensors
caliper paint
and a fart pipe
17" rims
hankook tires
cold air intake
K&N filter
bandpass box
wires & fuses
500 watt amp
headlight bulbs
y-pipe
high flow cat
02 sensors
caliper paint
and a fart pipe
17" rims
hankook tires
cold air intake
K&N filter
bandpass box
wires & fuses
500 watt amp
headlight bulbs
y-pipe
high flow cat
02 sensors
caliper paint
and a fart pipe
The switch is nice to have to turn off the amps. Good if you have to remove the box for some reason but you leave the amp installed (avoids short-outs). Also good if your parents ever borrow the car. I am 26 and married but when I went home to see my parents my mother borrowed the max and they always seem to gripe about the bass...
lower the car with sturts and shock for better look, you looking at around $550 or so if you get a GD off .org or ebay springs.
also get a pulley , run from like $80-$180 depending on brand,
get some clear corners run about 20-40 on ebay
shift ****?
different color shift boot/e-bake boot
custom steering wheel leather 2 tone i tihnk www.leatherseats.com has someone correct me if im wrong
a different grill?
red/clears(rare for 95-96)? euros?
decals?
hope that helps!
shift ****?
a different grill?
decals?
hope that helps!
yea, im going to get clear corners, but i want something a litlle creative.
for example: i have the bandpass box w/ 2 12, i am going to face it towards the rear seat, put a neon light the hits w/ the music in there and open the thing in the rear to access the trunk, the plexiglass face will be position perfectly so that you can see 2 12's pumping in neon light
simple diy mods, or other things that are a lil more custom, not just bolt ons! haha
Originally posted by maxfanfromohio
Originally posted by phenryiv1
Have you played w/ the G-tech yet? Let us know how you like it.
Edit: I almost forgot- young grasshopper, you must work on your quoting skills...
blue led in the window switches? how do you do that? what led is there?
Changing window LED
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
Sep 24, 2015 06:56 PM
