y-pipe for New Yorkers
Old Apr 7, 2003 | 01:18 PM
joew's Avatar
What did you do to pass the emission test for New Yorker?
Which y-pipe are you using? Thanks.
Old Apr 7, 2003 | 01:29 PM
dmBK's Avatar
How 'bout them cliffs?
Re: y-pipe for New Yorkers
any fed-spec pipe will do. make sure your car is warmed up before u do the inspection.
Old Apr 7, 2003 | 01:30 PM
FLO_BOY's Avatar
hey -- I'm not from NY, but a Y-pipe is a Y-pipe is a Y-pipe...
As far as I know, all Ys are basically just metal tubes that let
air flow through...So, I don't think brand matters -- you'll still
be removing the pre-cats.
Mind you, the pre-cats are only affective when the car is cold, so
when you go for emmissions, just make sure you're nice and warmed up!
FLO_BOY
Old Apr 7, 2003 | 01:37 PM
joew's Avatar
Re: Re: y-pipe for New Yorkers
i'm curious, pre-cat regulates cold air. how?
Old Apr 7, 2003 | 01:47 PM
FLO_BOY's Avatar
Re: Re: Re: y-pipe for New Yorkers
if by "regulate" you mean "clean", then it does...how, well, I dunno.
FLO_BOY
Old Apr 7, 2003 | 02:38 PM
Geophrum's Avatar
What is a Pre-cat you ask?? Well, it is put at the start of the exhaust system to function for "cold-start emissions." As such it is smaller than the main catalytic converter and thus heats up more rapidly to become active first with regards to catalyzing the exhaust gases.
Old Apr 21, 2008 | 07:22 PM
svezarov's Avatar
Is any of you guys that have replaced their stock y-pipe willing to sell the original? My stock is going to break at the flex section at any moment and also I don't want to take risks with the emission tests, so I would like to buy OEM.
Old Apr 21, 2008 | 08:20 PM
Tatanko's Avatar
Bacon Lover
A New Yorker?
Old Apr 21, 2008 | 10:15 PM
pimp349's Avatar
I passed with my stock - rusting/leaking flex - and then got a stillen and passed, not even warming up, got in and drove to the shop around the block. Stillen is a bit noisier than stock, just to let you know...
Old Apr 21, 2008 | 11:02 PM
Ruartur's Avatar
Passed 2 inspections no problem on topspeed pro y-pipe. You don't need to warm up your car either, if your car is newer than '96, all they do is put you on a computer to see if you have any check engine codes. If you don't (with an aftermarket y-pipe you won't) you're good to go as far as emissions.
Old Apr 21, 2008 | 11:08 PM
beez5spdmax's Avatar
i have a buget exhaust system in my max and passed my emission i live in queens.if u have a check engine light then u wont pass inspection if ur max is 96 n up they stick the computer.but if your max is 95 n under they stick the computer in your muffler.
Quickywd01
Sep 21, 2016 09:36 PM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
