I changed my Original head light bulbs. and put this brand http://www.eurodezigns.com after market light. Does anyone know if they have problem with after market blue bulbs. Are they safe to use?
Thanks In advance.
Thanks In advance.
several people have had problems with the harnesses burning out with xenon bulbs. some possible causes are the wattage is too high, a bad ground with an upgrade wire harnesses, or simply just dirty connectors inside the harnesses which results in more resistance.
i have plasmaglow headlights from www.aieonline.com and have had no problems since i replaced my harnesses with new ones from pepboys.
Thanks for the info, someone told me that these type of bulbs will burn the gasket inside the head lamp, and also they will burn the chrome plastic inside, did anyone had problem like that. The thing is i don't want to replace my head lamps for $10 bulb like that.
Quote:
I am pretty sure u won't melt your housing or any compenent inside it, but if the wattage is too high u will burn your sockets just like I did with my 80/85w bulbs.Originally posted by CystumMax
Quote:
ThanksOriginally posted by optimus310
You sure it wont melt anything inside? If it draws more wattage then it could be that it gets hotter then the normal bulb....
the one i have it is a 80/100w, I have checked the wires they look fine. I look inside the head lamp and it looks like the middle plastic in the center on top of it looks like it has been melted a little bit. the plastic i am talking about is where the bulb goes in and gets hidden behind this plastic it is in the center.
I don't know I might just take them out. and put back a reqular voltage bulbs but a little brighter.
I'm gonna call Euro Dezigne tommarow and aks them if they had any problem like that.
Oh ya I am sure cus thats not plastic is some sort of metal. I don't know the name of it but it won't melt. But if you are gonna be using 80/100w bulbs u might want to upgrade your hardness or just ground it to the body of the car. The 80/85 I had melted both of my sockets. Then they started to melt the nect sockets. The only thing that melts is the ground thing.Originally posted by CystumMax
