hesitation????????
Old Apr 9, 2003 | 05:40 PM
RI-Max's Avatar
hesitation????????
hey guys what would cause a hesitation, it does it at WOT or normal driving.
bad TPS/vacuum leak??? cause i has a whistling noise in idle but neva did it after i adjusted my idle 2 850/900 rpm.
Old Apr 9, 2003 | 07:08 PM
RI-Max's Avatar
bump!!
Old Apr 9, 2003 | 07:43 PM
Dev's Avatar
Dev
be more specific with "hesitation"
do you mean the car had engine hiccups? like a hesitant acceleration repeatedly?
or when you stepped on it the car was just altogether slow to accelerate?
Old Apr 10, 2003 | 06:54 AM
RI-Max's Avatar
yes hiccups at WOT!
Old Apr 10, 2003 | 10:03 AM
95maxmadman's Avatar
Don't mean to bogart your thread...
Can someone give reasons/fixes for each???
When I go WOT, it hangs there for a sec. like nothing's happening
then all of the sudden....NNNEEEEEOOOOWWWWWW...
Old Apr 10, 2003 | 10:17 AM
funmax's Avatar
This is exactly what happend to my car, but it only happend when i go WOT on highway.
i'll adjust the throttle cable and clean the throttle body, hopefully that can fix the problem.
Old Apr 10, 2003 | 10:24 AM
WhiteMax96's Avatar
Did your sparks plugs are old ones? Fuel filter?
Old Apr 10, 2003 | 10:28 AM
NiNe7-Gxe's Avatar
automatic down shifting?
Old Apr 10, 2003 | 10:40 AM
I'm doing the plugs and pcv valve sunday.
The plugs aren't that old but i'm switching to coppers.
The fuel filter was done last spring...
Cleaned the tb last weekend.
Old Apr 10, 2003 | 11:45 AM
jt151's Avatar
Spark Plug / Acceleration Delay
Sounds like the spark plug or fuel system. How many miles do you have on your car? Have you had your fuel injection system cleaned? Also, I'd stick with the NGK Platinums instead of going copper.
Anyone feel free to correct me if I'm wrong:
The delay from a rapid acceleration is due to the time the programmed ECU takes to communicate with the actuator. The actuator then has to build up the correct pressure to advance the throttle.
I think you can have the ECU reprogrammed to allow quicker response.
Old Apr 10, 2003 | 11:50 AM
I'm going with the coppers for the higher spark/less $$$ combo.
And it gives me a project every 30k.
I'm pretty high mileage. 107k. When you say to have the fuel system
cleaned, do you mean just using injector cleaner in the tank. yes, i did recently.
Old Apr 10, 2003 | 12:52 PM
RI-Max's Avatar
ok my car has 144,000 changed the fuel/pcv last spring. plugs this winter
Old Apr 10, 2003 | 01:33 PM
funmax's Avatar
i just clean my car TB, and reset the ECU. i drove it on the highway and go WOT, everything seems back to normal now.
Old Apr 10, 2003 | 01:37 PM
BlueBOB's Avatar
If you are an auto... question answered. That is the problem with an auto. They lag. Mine does that every now and then and it makes me hate it more each time . Oh well.
Old Apr 15, 2003 | 10:06 AM
Sir. Max's Avatar
I'd make sure you have the right heat range spark plugs in. I had the same problem because I had BKR6EVX-11 (platinum)plugs in. I changed to the BKR5E-11 plugs (copper) and the problem was gone. The BKR5E-11
are the stock heat range that run a bit hotter than the BKR6EVX-11.
D
Old Apr 15, 2003 | 10:55 AM
97MaximaSE's Avatar
well i was having this naggin hesitation problem for over a year now....ive replaced and cleaned every sensor and valve the car has. The other day i took out my plugs which still looked good....cleaned them off with some brake cleaner and put them back in. Hesitation is now gone. I spent over 500 bucks in sensors to fix a problem that took 15 min to take care of so try checking your plugs first.
JoshG
51
Sep 21, 2015 10:41 PM
jchronis2552
Sep 21, 2015 05:52 AM
trungg86
Sep 4, 2015 04:58 AM
conansriver
Sep 3, 2015 06:38 AM
