cruise control dont work :(
Old Apr 11, 2003 | 07:05 AM
s0ber's Avatar
Anyone have any ideas why my cruise control doesn't work??? It never worked since I bought the car... I turn on the cruise switch to ON and it lights up green but when I use the steering controls to set it, it dont do nothing
Old Apr 11, 2003 | 09:54 AM
MaximaMoJo's Avatar
First of all tear your steering wheel column apart and check the connections. Next, check your clockspring. This is what is causing my cruise to turn off when I turn on my turn signal. I also heard a bad ground can cause havoc to the cruise control system. There are a lot of things that could be causing the problem. I eventually had to take my Max to reputable shop to track down the problem. I still haven't got it fixed yet because it is $500 for the clock spring & install. I can live with not using my turn signal!
Old Apr 11, 2003 | 11:03 AM
s0ber's Avatar
$500!?!? Guess I wont have cruise control Berly use it just wondering why the **** dont work.. hehe
Old Apr 11, 2003 | 01:27 PM
kenju4u's Avatar
hey i think mine is start to go..cause somtimes it work and sometimes it doesnt. I have had the same symptoms as you are having. The main CC light comes on but when i press the streering column switch to set cruise nothing happens, but then i stop and shut of the car and restart it...everything start working normally..werid huh?
Few days ago i also got a check engine light which said something about transmition signal to ECU and vehicle speed sensor....well i reset the ECU and the light is gone but if there is a genuine problem with these sensors then i think the CC would get effected...I am gonna see if the light comes on again and if it does i am gonna start replaceing the sensors.
Did u guys get any check engine lights? ever ran a test on the ECU? maybe its might help...if its the speed sensor...someone told me thatis pretty easy to change and its only about $45 bucks.
MikesChevelle
Nov 23, 2024 11:17 AM
stevesmax
Dec 17, 2020 11:57 AM
trasmadean
Feb 1, 2017 08:20 PM
schmellyfart
Sep 25, 2015 04:47 PM
MikesChevelle
Aug 6, 2015 11:36 AM
