FSTB hitting a pipe?
Old Apr 12, 2003 | 07:26 AM
GMT_MAX's Avatar
I just installed a FSTB in my 99 GXE, and the mount (not the bar, but the mount on the end) on the passenger side hits some sort of pipe. Picture here: http://www.cardomain.com/member_page...page_id=334816 (scroll down to the end). Any clue what that is? Anything to worry about? The pipe seems to be somewhat flexibly mounted, with a bendy metal bracket and a rubber bushing, so it's not like there's a lot of force between the bar and the pipe, but still....
GMT
Old Apr 12, 2003 | 07:28 AM
gtr_rider's Avatar
192.168.1.1
Thats the A/C Condenser Piping, what you want to do, which is what I did was that there is a bracket holding up the pipe rigt underneathe the FSTB. Loosen it up and sort of push the piping down a bit and tighten up the bracket. It helped mine have some space.
Old Apr 12, 2003 | 08:43 AM
KsuMax's Avatar
Cheesing away...
Will it hurt the A/C if you leave the fstb there? Mine has the same problem.
Old Apr 12, 2003 | 09:06 AM
Gotrice4's Avatar
It should not hurt anything...I've had mine on for like 3 years now without a problem. But I'd prolly either watch it or do what gtr_rider suggested...i might have to try that...
Old Apr 12, 2003 | 09:56 AM
GMT_MAX's Avatar
I tried messing with the screws on the AC pipe mount like gtr_rider suggested, but couldn't really get any clearance that way. Then I put a washer between the body and the mounting for the AC pipe and it got a little better. Still touched, but not as much force. Finally, I said scruit and used like a hose clamp thing to pull the AC piping more towards the center of the car (and away from the fstb mount). A long ziptie would probably work equally well, but the ones I had weren't long enough. I'll probably still keep an eye on it though, I don't want to start spewing AC coolant while I'm driving down the highway...
GMT
Quickywd01
Sep 21, 2016 09:36 PM
D Mason
Jun 21, 2016 04:43 AM
doctorpullit
Dec 12, 2015 09:39 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
