Noisy stabilizer bushings
Old Apr 13, 2003 | 06:06 PM
Ferd013's Avatar
Hi,
New here; hope you can help. (love my Max!)
Noisy stabilizer bushings driving me crazy
sound goes away after a carwash or when it rains but as soon as things dry out there we go again. The worst is when driving VERY slowly, like into a driveway.
A garage sprayed some dry lub on them and it went away for about a week or two.
any suggestions!?!
Ferd013
Old Apr 13, 2003 | 07:03 PM
Sin's Avatar
Sin
Re: Noisy stabilizer bushings
Originally posted by Ferd013
Hi,
any suggestions!?!
Ferd013
Yes, lubricate them with a plastic/polyurethane/rubber safe lubricant.
Old Apr 13, 2003 | 07:36 PM
Dave Holmes's Avatar
Re: Re: Noisy stabilizer bushings
Use KY if you don't have the polyurethane lube. Safe for rubber and polyurethane.
Dave
Old Apr 13, 2003 | 09:31 PM
Keith P's Avatar
Plumber's grease. Does not react to anything. Super vaseline. Do NOT use for sex!
Old Apr 14, 2003 | 04:07 AM
njmaxseltd's Avatar
Change them! Their squeaking because they are all dried out. Courtesy Nissan has eurathane bushings for the sway bar. The set should run you about 30 bucks which includes the end links and the 2 main bushings.
Old Apr 14, 2003 | 04:33 AM
Rogo02SE's Avatar
Dude,
I got the same problem in the front.
What do I do???
Does your front or rear make the noise???
Old Apr 14, 2003 | 05:55 AM
95Max's Avatar
2 options you can try.
1) lube the bushings with waterproof marine grease.
2) get new bushing for the bar. But go to suspension.com they are lease expensive then courtesy
Starrider
Dec 18, 2015 04:43 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ColdCananda
Sep 20, 2015 10:45 PM
