Harlan switch question.
Old Apr 15, 2003 | 12:32 PM
hacim105's Avatar
Which wires connect to what when connecting to the MEVI. There is a white, green, black, and red wire. The white is separate so I'm guessing it goes to the tach. Correct me if I'm wrong. What about the others?
Old Apr 15, 2003 | 01:25 PM
CalsonicSE's Avatar
Re: Harlan switch question.
There is a group of three wires. Green - tach; black - ground; red - power.
There is a single wire. In my case, it was black, but apparently your's is white. Anyway, it is a switched ground meaning it should go to one of the terminals of the dawes device solenoid.
Old Apr 15, 2003 | 01:36 PM
Requin6's Avatar
Here is how i wired mine up...note that i also use a relay.
Wires coming out of the Harlan go like this...
Red - To "85" on relay & Positive wire on cigarette lighter connector.
Black - To negative wire on cigarette lighter connector.
White - To "86" on relay
Green - To ECU wire for coil #1 OR wherever you want to pull your RPM source from.
The wiring on the relay goes like...
"85" - To the Positve Cig lighter wire
"86" - To the white HARLAN wire
output - Vacuum device
Ground - Chassis ground (in my case, bolt on shifter plate)
From the Vacuum device...
input from the relay
and then a fused line to the positive terminal on the battery.
here is a picture of some notes that i have...
that might help in deciphering what i just said.
--Paul
gavin68
Sep 18, 2021 12:36 PM
doctorpullit
Mar 29, 2016 11:08 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
lrb6805
Sep 24, 2015 05:03 PM
