Help me...Brake Problems!
Old Apr 15, 2003 | 10:07 PM
looney662's Avatar
So I got my rotors, pads, and SS lines on a GD on the forum. Installed the rotors, pads and 1 SS line (Got dark couldn't see a thing ! Ok here's my problem when I step on the brake pedals it is nice and hard, but when I turn on my engine all the pressure is gone ! So right now I don't have any brakes my emergency brakes work that's it! Help me out guys!
Old Apr 15, 2003 | 11:14 PM
looney662's Avatar
Also when i hit the brake pedals i hear a clicking noise at my AT shifter! Is this another problem?
Old Apr 15, 2003 | 11:49 PM
Tuna's Avatar
you got air in ur brake lines.. put on all the ss lines on first then have someone help u bleed ur brakes.. you could do it urself but it might take some time.. i dont know about the clickin sound, but when u have no pressure that almost always means air in the brake lines..
Old Apr 15, 2003 | 11:51 PM
MaxEffect414's Avatar
The noise is normal in your shifter and you have air in the line, you have to bleed the brakes.
Trance
Old Apr 16, 2003 | 12:24 AM
looney662's Avatar
Thank's alot guys! I have been searching on honda-tech.com and found the same answers (I am going to get for this)I think I did a really really bad job on bleeding the brakes.
Old Apr 16, 2003 | 05:43 AM
fisher01's Avatar
Unless you have the special tools to bleed the brakes by yourself, bleeding the brakes is a 2 person job. One to press down the pedal while the other person opens and closes the bleeder screw.
Old Apr 16, 2003 | 06:09 AM
d_hammmer's Avatar
If you have an Auto, the clicking noise is a relay.
The relay is used to check that you have your foot on the brake before it will allow you to shift out of PARK
Old Apr 16, 2003 | 04:50 PM
looney662's Avatar
Thanks for all the replys! I just fixed it, bad bleeding job! The car stops on a dime now !
Old Apr 16, 2003 | 05:21 PM
karguy's Avatar
No that is the shift interlock and is normal!
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 24, 2015 07:01 PM
