So how much would u spend to change the color of you clock? $10? $30? How about a $1
Old May 2, 2003 | 11:30 AM
  #81
danimsta's Avatar
o yeah lol forgot my pic
here it is
THANKS MAD DHAN!
Old May 2, 2003 | 12:31 PM
  #82
Street Reeper's Avatar
Handsome
Originally posted by geo1317
sweet, i got a new project, thanks. im also going to try and do the same for the ACC, hope it works. great gob.
Where did you get the chrome gauge rings, and how tough are they to install? Some people have devalued their car by half by messing up the odometer when trying to install gauges, do these rings take as much effort?
Old May 2, 2003 | 12:32 PM
  #83
danimsta's Avatar
i have them, and they are VERY easy to install.. just gotta open dash, take off clear plastic that covers ur gauges, and glue the rings on!
u can see them in my pic
and also in my mod page
Old May 2, 2003 | 12:41 PM
  #84
Handsome
What kind of glue did you use and where did you buy them, I do not have an e-bay account, does anyone else sell them?
Old May 7, 2003 | 01:13 PM
  #85
NotNew!!NewSN!!'s Avatar
Originally posted by SprintMax
i changed my clock to silver
thats bad ***, but man does ur center console look like poo. Get some armor all on that bish.
Old May 7, 2003 | 01:16 PM
  #86
danimsta's Avatar
contact
phsinvent@aol.com
i got the glue with teh gauges....
he should provide it, if he has some in stock
Old May 9, 2003 | 07:11 AM
  #87
cam_honestiam's Avatar
Cheaper, Easier
For those who do not want to buy a whole role of cellophane:
I bought a cellophane party bag (dark violet) for $.10 at Roberts Crafts. They had other colors as well. The red (darker red) made the clock red, the violet made the clock indiglo blue-->just what I was looking for. In all, I spent $.12 -- I think I got you all beat!
I also cut the pink/blue wire to disconnect the dimmer. I like it better having my clock brighter indiglo all the time.
Old May 9, 2003 | 08:02 AM
  #88
AlanHoskins's Avatar
I have a stock bose stereo, is there anyway to change its color also? It looks almost the same as the clock did.
Old May 9, 2003 | 08:06 AM
  #89
Maxman2000's Avatar
That's one mod I'm gonna do today (if I can find that paper ).
Old May 9, 2003 | 08:07 AM
  #90
There is a way, but it most likely involves removing the entire unit from the carriage. Also, I think you have to cut through some glue. I looked at doing it yesterday, but I did not have the time to dissassemble the entire stereo to see how the cover was attached.
Old May 9, 2003 | 08:23 AM
  #91
Handsome
HOW DID YOURS TURN OUT??
Can you tell there is celephone over the clock in the daytime?
How did you get around the hour/minute buttons that are used to set the clock?
Did your dash go back together flush or is there some gap now?
Old May 9, 2003 | 08:35 AM
  #92
MINE TURNED OUT SWEET AS HONEY!
You can absolutely NOT detect any cellophane on mine, at any time--day or night. Indiglo blue, through and through. I removed the entire vents with the clock (those vents were dirty, needed to be cleaned!) and added some foam around the back of the vents to lessen the air escaping into the console from the blower. I tightened screws and bolstered the fittings so that my vents would snap in better than they were when I removed them (previous owner was careless). I was careful to align everything properly, and added some felt around all of the edges for a tighter fit (I had a tiny creak sound sometimes). You don't need to worry about getting around the buttons. You completely remove the clock, take off the cover, and cut the cellophane to just barely cover the entire LCD window. I then used electrical tape to tape it snugly to the rest of the unit, not interfering with the buttons at all.
Absolutely no gap in dash, looks better than ever. I also used some tape around the parts I took out to reduce any gaps that were previously existing.
Old May 9, 2003 | 08:38 AM
  #93
DirtyBurghLoMax's Avatar
how did u change the buttons for the climate control
Old May 9, 2003 | 08:52 AM
  #94
Mine is not climate control. Sorry, can't help you there...
Old May 10, 2003 | 06:45 PM
  #95
Maxman2000's Avatar
Originally posted by djshawnee
its an LCD... it has no LED's.
also, how dim is it with only the red cellophane? how much dimmer would it get if i put the blue on it also? will i still be able to see it during the day? just white would be cool though.....
It's an LED display.
Trust me, My Dad's an eletronic engineer and he works with thses things.
Old May 11, 2003 | 11:55 AM
  #96
Max96LSU's Avatar
here's a link to make the clock always stay bright.
http://forums.maxima.org/showthread....ht=clock+light
Old May 11, 2003 | 12:33 PM
  #97
ptatohed's Avatar
Licensed to Spell
:o)
Sheesh, I take a month or so off from the .org and I come back to something so cool. I hope I didn't miss anything else. Good job Mad. I hope this works for the electronic climate control.
Old May 11, 2003 | 12:36 PM
  #98
ptatohed's Avatar
Licensed to Spell
:o)
Those panels are worked over there Sprint. Time to replace those bud.
Old May 13, 2003 | 07:42 AM
  #99
IT IS NOT AN LED!!!
MaxMan2000,
Your dad may be an engineer, but that does not change the fact that the screen on the Maxima's clock is an LCD.
A little electronic lesson for you (and your dad):
LCD = Liquid Crystal Display (aka-digital number displayer)
http://home.howstuffworks.com//digital-clock.htm
This link will teach you and your dad the difference between the two.
LED = Light Emitting Diode (aka-a little tiny light, often seen on rear spoilers)
http://electronics.howstuffworks.com/led.htm
This link will clarify your confusion as well.
  #100
IT IS NOT AN LED!!!
Old May 13, 2003 | 09:47 AM
  #101
ay5800's Avatar
contacts
are they bausch and lomb? or j&J also are they disposable????????
Old May 13, 2003 | 10:52 AM
  #102
aznsap's Avatar
i have successfully changed the color of my clock, acc, and bose headunit. in continuation of mad dhan's clock mod, i decided to try the bose head unit also. check out this tread: http://forums.maxima.org/showthread....hreadid=215130
before:
after:
Old May 13, 2003 | 12:02 PM
  #103
ptatohed's Avatar
Licensed to Spell
before:
after:
Nice!
Old May 13, 2003 | 12:41 PM
  #104
aznsap's Avatar
Originally posted by ptatohed
Nice!
has anybody done the bose headunit before? or am i the first? neway, i have a brief write up typed up along with pics on http://www.cardomain.com/member_page...=352601&page=2
i can't think of anybody that has done this before? i kinda jus wanted to do everything after mad dhan pioneered the clock lcd
Old May 13, 2003 | 01:57 PM
  #105
ptatohed's Avatar
Licensed to Spell
:o)
has anybody done the bose headunit before? or am i the first? neway, i have a brief write up typed up along with pics on http://www.cardomain.com/member_page...601&page=2
I am proud of you guys.
Old May 13, 2003 | 03:06 PM
  #106
aznsap's Avatar
hey ptatohead, i just noticed you homepage. how did you black out your chrome window trim and white out your door handles? i have a white 95 gle, so i want to get rid of the chrome as well.
Old May 13, 2003 | 05:12 PM
  #107
ptatohed's Avatar
Licensed to Spell
:o)
I just paid to have them painted. The doorhandles are fine but the window trim started to chip in a few spots. I just ended up buying the black SE trim. I have yet to install it though. I'm famous for buying stuff and let it sit in my garage - lol.
Old May 13, 2003 | 10:00 PM
  #108
Speebs's Avatar
I aim to misbehave.
I believe it is an LED display. You can buy 7-segment LEDs anywhere (http://www.eled.com/product.asp?cata...id=ESA56-11EWA). Color LCD displays require pixellation and RGB diffusion for each pixel, which our clocks clearly don't have (it would be a tremendous waste anyway). A basic non-color LCD just polarizes the light so that it is either absorbed by a certain area of the display (dark)or reflected (light) and may or may not be backlit.
7-segment LEDs have a separate LED in each segment which are wired in parallel with a common anode or cathode. As current passes through each LED segment, it is lit up by the bulb. The display in your bedside alarm clock is made of LEDs, whereas color displays like those on cell phones are LCDs.
Old May 13, 2003 | 10:15 PM
  #109
aznsap's Avatar
back on topic.... i got a roll of the red cellophane for ~80 cents. so i was able to do
this----> http://maxima.cardomain.com/member_p...=352601&page=3
for less than a dollar and like 5 hrs last night
Old May 14, 2003 | 12:03 AM
  #110
95emeraldgxe's Avatar
absolutly genius - this has to be one of the best mods possible
Old May 14, 2003 | 12:25 AM
  #111
Mad Dhan's Avatar
Great work on the clocks guys. I see yours (asnsap) came out very nice and clean.
btw guys, the clock is not a lcd nor a led. It is a vacuum fluorescent display(VFD).
Old May 14, 2003 | 06:31 AM
  #112
araffio's Avatar
1 red piece, 2 blue pieces. Makes a nice difference...
Pic of mine:
Old Jun 16, 2003 | 06:09 PM
  #113
RSA_MAX's Avatar
I too am doing this mod, however, I've removed the clock from the dash, but can't get the plastic cover, covering the lcd to come off. The two hooks on the sides of the unit seem to not want to come off. Anyone have this prob? I mean, im pretty sure this plastic piece comes off, and there is a little lcd screen in there? i've tried everything to get this plastic case off but it's not coming? i don't just put the cellophane over the plastic do I? confused..
bob
Old Jun 16, 2003 | 06:34 PM
  #114
RSA_MAX's Avatar
well i got the cover off, and i put one piece of red and one piece of blue over the lcd, installed it back int he car, but my clock is still green? WTF! always me, my bad luck..
bob
Old Jun 17, 2003 | 06:54 PM
  #115
jaysway's Avatar
hey man, thas awesome.... and hey, sidenote... how DO you disconnect the auto dimmer.... i HATE that my clock goes dim when i turn the lights on
Old Jun 17, 2003 | 07:50 PM
  #116
Sorgasm's Avatar
http://forums.maxima.org/showthread.php?threadid=35742
Old Jun 17, 2003 | 08:37 PM
  #117
Pinnacle's Avatar
pure genius
thanks for building the bridge for the rest of us to walk across
SHIFT_weekend project #2
Old Jun 19, 2003 | 09:23 AM
  #118
venompwr2's Avatar
if this worked on the clock, if I were able to put this cellophane on the switches for the windows and locks would it produce the same effect or no?
Old Jun 19, 2003 | 12:40 PM
  #119
Slickismax's Avatar
It might, but you can just change out the LED's in the switches.
Old Aug 17, 2003 | 07:51 AM
  #120
mikey07005's Avatar
Why does it look like someone took a jackhammer to your dash
-Michael
