Spark plug problem 99 GXE auto- HELP!!!!
Old Apr 17, 2003 | 03:11 PM
RichMax's Avatar
Boosted like Snipes tax refund
I installed new plugs in 5 of the six cylinders in my Max. After trying in vain to get the 5th cylinder spark plug out, I found it was stuck in the cylinder and the hex nut on the spark plug (the 5/8" socket nut which allows you to remove it with a rachet) seems to have melted or otherwise disappeared. In other words, the plug is round where it should be a socket. I haven't the slightest how to remove it, what tool would be required, or how much it would cost to replace.
Anything?
Old Apr 17, 2003 | 03:44 PM
fisher01's Avatar
Sounds like the nut is stripped. I remember a poster here who actually broke off the plug in the cylinder. There was a long thread about how to possibly remove it including dismantling the engine. he never did post back to let everyone how it was removed. You may have to leave this one up to the mechanics. Anyone have ideas?
Old Apr 17, 2003 | 03:48 PM
sbslacker's Avatar
Brutal. Maybe put some glue on the inside of the spark plug socket and wait for it to dry while it's on the plug? See if the glue or epoxy or whatever will hold tight enough so that the force req. to remove the plug won't break it loose.
You'll probably have to buy another socket but at least you'll have the plug out.
Old Apr 17, 2003 | 03:50 PM
Sprint's Avatar
the maxima is Japanese all nuts and bolts on the maxima are metric
if its a socket in there, put the attachment back in the hole and loosen the spark plugs.
Please follow my write up:
http://www.sprintmax.com/tails/sparkplug.htm
Old Apr 17, 2003 | 04:16 PM
njmaxseltd's Avatar
Is the boot from the coil stalk stuck on the plug which is not allowing the socket to grab the hex? Check the coil you pulled out of that cylinder and make sure the rubber boot is on the end.
If not, there's an easy way to get it off the plug and back onto the coil pack's stalk. Read the FAQ's.
Old Apr 18, 2003 | 06:20 AM
RichMax's Avatar
The boot isn't stuck on the plug itself. The nut, however, is almost definitely stripped. The best suggestion thus far parallels one I was thinking of myself- applying an epoxy to the plug itself and the socket to remove the bad plug.
Old Apr 18, 2003 | 06:26 AM
njmaxseltd's Avatar
Get a long 6 point socket 1mm smaller and tap it onto the stripped hex. A 6 point might work, but then again it may just strip it more.
Good luck!
Old Apr 18, 2003 | 06:40 AM
fisher01's Avatar
Good luck!
Agree, try a smaller socket first before doing anything. I've had success doing this when removing a stripped lug nut. Please keep us posted as to how you eventually remove the plug. Good luck, hope you get it removed soon.
Old Apr 18, 2003 | 09:13 AM
supercobraz's Avatar
I think Sears now sells a special attatchment that is made to drill out stripped and broken off nuts and bolts. You would have to actually break off the plug though and risk making it worse. But that could be your last alternative...
Old Apr 18, 2003 | 09:40 AM
ZuMBLe's Avatar
I used a standard sized sparkplug socket to take mine out.. It worked. I dono!
mvm062
Nov 30, 2020 09:00 AM
markevans999
Oct 25, 2015 08:27 AM
chernandez1278
Sep 16, 2015 01:18 PM
rnb754
Sep 14, 2015 11:39 PM
Maxima Pride '07
Sep 12, 2015 07:29 AM
