Stuttering Idle
Old Apr 17, 2003 | 11:45 PM
FiSH
Stuttering Idle
My idle in my 99 Max sort of stutters. The RPMs bounce downward by about 100 rpm and I feel it shake the whole car. Sometimes its there and sometimes it isn't.
Any ideas?
Dave
Old Apr 18, 2003 | 12:11 AM
BLacKMax69's Avatar
coil pack is bad/spark plugs
Old Apr 18, 2003 | 05:32 AM
Street Reeper's Avatar
Handsome
Why are you on my ignore list
Anyway does it happen often? My car has done this twice, it only happens when I let off the key (turning it to engage igniiton) to early, the car will stutter then die. After this I will try it again and everything is fine, does this sound like your symptoms?
Old Apr 18, 2003 | 05:53 AM
breaux124's Avatar
Try a few things first:
- Clean / Replace your air filter
- Clean your throttle body: http://www.motorvate.ca/
- Search for info on IACV (Idle Air Control Valve), this might need some adjusting or cleaning.
I had the same problem and once I cleaned my very dirty intake, and cleaned my throttle body the problem went away. That was over a year ago and it hasn't come back.
Old Apr 18, 2003 | 06:28 AM
njmaxseltd's Avatar
Is your check engine light on?
Better yet, is it working? (comes on when the key is turned)
Old Apr 18, 2003 | 08:21 AM
sil SE's Avatar
my idle hits 500 sometimes, and stays at just shy of 600
.little shaky.
Old Apr 18, 2003 | 08:33 AM
elcid's Avatar
I ahve this exact or very similar problem..on applying the brake sometimes mine shoots down to almost zero then pops back up. BUt it is still low, I changed my plugs about 3 months ago with NGK Platinum plugs. But I can feel it in my steering wheel also.
And why are you on my ignore list also? Although I just checked and I ahve nobody on my list...weird.
Old Apr 18, 2003 | 10:05 AM
FiSH
I'm on my OWN ignore list for some reason!!! I can't see my own posts or go into my profile...!!
I just changed my plugs and it helped a bit I think but it still happens. The problem is not yet solved.
Any more ideas?
Old Apr 18, 2003 | 10:22 AM
FiSH
I have also cleaned my TB.
I feel the whole car bounce, sort of in the steering wheel... It's wierd...
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
