2 problems i have.
Old Apr 18, 2003 | 07:53 PM
Torgus's Avatar
2 problems i have.
hey i got these two odd little problems with my 97 max. the diver's window only rolls down 3/4s of the way
also after the car has been sitting all nite when i turn the key it starts up and then putters a bit then stalls. but if i give it gas its fine. any idea how to fix this or what is causing it? *Thanks In Advance
--blaze...
Old Apr 18, 2003 | 08:38 PM
HarrisH's Avatar
Hey Tia how are you as to your power window it could be your motor or a relay problem, not sure which, as to your car stalling more than likely a dirty throttle body, clogged up fuel filter, dirty air filter, spark plugs, PCV Valve, more than likely a dirty TB.
check out motorvate.ca for instructions on how to clean it, take care and good luck. God Bless.
Old Apr 18, 2003 | 08:47 PM
Keith P's Avatar
The window could be bogging on debris in the channels or else where in the mech. The hard torque pulls the amps up and the controller stops the motor. Try dry silicon in the channels first.
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
