HELP!!!!! tranny problem
Old Apr 19, 2003 | 01:02 PM
mikey62681's Avatar
I have a 95 auto, and it never has done this before but it was shifting just fine. And then i went and washed my car today and i washed off the motor everything was ok untill i went and picked up my girlfriend and now it shifts really hard 1st to 2nd, but its not as bad through the other gears but its alot worse then it was before. Does it sound like i may have knocked off a vacume hose or should i start looking for a new tranny. I hope someone can help me out thanks
Mike
Old Apr 19, 2003 | 01:09 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Re: HELP!!!!! tranny problem
Mike
Does it make any noise from first to second? or any other gears? if they power washed your engine could be well they messed up something. check your cluch fluid.
you could also check the ecu. but then yours manual.
Old Apr 19, 2003 | 01:12 PM
mikey62681's Avatar
I checked the tranny fluid and it looks dirty but not that bad. Also is there a certain color i should be looking for?
Old Apr 19, 2003 | 01:17 PM
CystumMax's Avatar
I use to have manual car, 87 Acura legend. I had problem like that. It was the master cylander for my cluch that went bad. they changed it and the problem was gone. Your fluid should be yellowish color, clean. yous hould not see any black metrial in there. but then i am not expert on trany. If i was you i wouldn't drive the car as much. I know its weekend. But something could go really wrong with your car, something is not working right. just on monday take it to tranny shop, i leave in NY longisland, there is guy by my house who checks this stuff for free. just don't drive your car and on monday take it to tranny shop, just be on the safe side.
ALso do you hear any noise when you change from first to second?
Old Apr 19, 2003 | 01:19 PM
mikey62681's Avatar
Thanks for your help.
Old Apr 19, 2003 | 01:24 PM
CystumMax's Avatar
U welcome.
Old Apr 19, 2003 | 04:39 PM
njmaxseltd's Avatar
Sounds like the dropping resistor failed or shorted out. It's located on the driver side strut tower, wedged between the the air box and the tower. Make sure you didn't knock a wire off while you were drying off the engine compartment. Or perhaps it shorted out. Thats the only thing that would cause the sudden change in the way the car shifts from 1,2 and 2,3. If the part has shorted out, it's only a $20 part from Nissan. Don't be fooling into a new tranny when that resistor may be your problem.
pktaske
May 6, 2016 07:49 AM
Socalstillen
Sep 20, 2015 11:46 PM
iamute
Sep 20, 2015 05:22 PM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
