Cleaning your headlight housings...
I just got a pair of used 99 headlight housings. I cleaned the outside, but still looks dirty from the inside. Whats the best product to use to clean the plastic cover as well as the chrome part inside on the housing itself? I dont want to mess up, and I want it as clear as its suppose to be!
Re: Cleaning your headlight housings...
David
Re: Re: Cleaning your headlight housings...
Originally posted by d_warner
You can take the lens off of the housing and clean it. You'd do it just like doing the red/clear conversion for the tails. I took mine apart and did the AE headlights for the 4th gen. As for cleaning em, get some plexi polish from autozone for the lens, and some windex should work good on the reflector. Write up for AEs is on VQPower.com if ya wanna see how they look. OR my webpage. Good luck
David
David
I cleaned the inside of my housings last week, here's what I did.
Remove them from the car and bring them inside to clean. Spray a good amount of windex inside the housing, add a bit of water and one half of a piece of paper towel. (sounds crazy right?) Swish the windex and the towel all over the inside of the housing, like a sponge. Then dump the windex and water out, get the piece of paper towel out and rinse with plenty of warm water.
Next put another 1/2 piece of paper towel inside. Use good lint free towels and shake it around to soak up as much water as possible. I repeated that 3 times with 3 clean dry pieces of towel. Most of the water is absorbed into the towels but the inside is still wet. Next place them in the sun, lense face up, for about 3 hours or until there nice and dry inside. Reinstall them in your car and admire the crisp clean shiny silver insides!
Worked perfect for me, the housings look like brand new. Polish the outside of the lense with rubbing compond and then a nice polish and they come out crystal clear.
The best part of doing it this way instead of taking the glass off, which is tricky, is that the seal is never broken.
Did you have to re-aim the headlights when you reinstalled them?
David
David
Originally posted by joeymaxima
how do you get the headlight assembly off in the first place...i want to clean mine out
Ummm. Take off the grill. Like 5 clips. Then theres 4 nuts on the back of each housing. Make sure you unplug your lights.
David
That's a sweet trick, I'm going to give that a try before I try taking the housing apart
AaronL
11-15-2020 11:52 AM
sdotcarter
09-02-2015 09:53 PM
