Car stalls from high speed
Old Apr 20, 2003 | 06:53 PM
kev97se's Avatar
Hi , I need help with a problem I started to have recently. When I am coming off the highway and make a full stop my rpm's drop really fast and my car stalled at the light. I also noticed pretty low rpm's by just standing at the light and in drive - about 400-500 rpms. I already cleaned my throttle so it can't be that. I also pulled the codes from the ECU and I only got a Front Left Heated O2 sensor. Could it be my battery or my alternator??? Let me no what you think. Thanks
Old Apr 20, 2003 | 07:05 PM
97blackSE's Avatar
if it was the batt or alty, the car would not restart. also when it stalled, the lights and other instruments would have went dim b4 your stall...How fast were you going at the time of stall?
Old Apr 20, 2003 | 07:20 PM
kev97se's Avatar
I was just getting off the bridge and was going about 50 mph. My car stalled at about 10 mph and my steering wheel locked. I put the shifter into neutral and started it up right away. I think I'll go to the auto store and buy a charging system tester that checks the battery, alternator and charging system.
Old Apr 20, 2003 | 09:12 PM
rmb's Avatar
rmb
Call me crazy but maybe it's the front-left heated O2 sensor?
Your steering also didn't lock, the power steering just died. Get some muscle into it and it'll turn if you have to.....
-RMB
"From one who used to drive a 6,000 pound Dodge that stalled all the time"
Old Apr 20, 2003 | 10:11 PM
DaThrillr's Avatar
i was having this problem not to long ago i fixed by doing several things.... change feul filter(check old one to see if its clogged).... then clean throttle body really good with TB cleaner and use a longer pipe cleaner like 3" or so and really clean it and that worked for me.... then i adjusted my idle with little screw...
hope that helps
Old Jul 5, 2003 | 01:25 PM
97MaximaSE's Avatar
Re: Car stalls from high speed
hey the same exact thing is happening to me except it happens all the time everytime i slow down to stop....what did you do to fix it? I also get the front left heated 02 and also the rear o2 code
Old Jul 6, 2003 | 07:38 AM
97MaximaSE's Avatar
Re: Re: Car stalls from high speed
[QUOTE]Originally posted by 97MaximaSE
[B]
hey the same exact thing is happening to me except it happens all the time everytime i slow down to stop..I ended up having to get the car towed..what did you do to fix it? Also when i drove it late at night it didnt stall. It only stalled when it was hot but still hesitated on me. I also get the front left heated 02 and the rear o2 code(which has been on for months now)
Old Jul 6, 2003 | 11:49 AM
BrazilianMax's Avatar
kev97se,
Please check out all these other comments. I got the
same problem and opened a new subject on that last year.
http://forums.maxima.org/showthread....hreadid=164378
Good luck,
BrazilianMax
Old Jul 6, 2003 | 01:56 PM
trutank
Im sure its a vaccum leak,.. check all your vaccum lines for leaks and cracks...
most often its that vaccum line from your intake to the EGR.
That would most likely be the prob.
Old Jul 6, 2003 | 08:36 PM
Trutank,
Where are those lines located ? how can I check them
for leaks ?
Regards,
BrazilianMax
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
altome15
Aug 10, 2015 07:05 PM
