Compression Test Results
Old Apr 20, 2003 | 07:41 PM
xHypex's Avatar
Since I put a brand new starter and a new battery in my car this weekend I figured it was a good time to do a compression test before I start spraying. Results are are follows:
Cylinder (PSIs from 2 tests)
1 168, 168
2 172, 170
3 176, 170
4 170, 168
5 172, 180
6 172, 175
I tried to turn the engine over the same number of turns, but as you can see some tests may have gotten 1 more revolution of the engine. All in all the test was pretty easy, but I definitely need 1 step colder plugs before nitrous since I am already running hot.
The one concern I have was oil on my plugs. I found oil on the threads of the plugs, so there must be a leak from the valve cover or something. There wasn't too much oil, but does anyone know more about this? I was told that its relatively common, and as long as there aren't puddles it's not a huge issue (but at some point a new gasket set would solve the problem).
More pictures
-hype
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
mkaresh
Mar 12, 2018 06:48 PM
Sep 27, 2015 08:37 AM
