Making sure VI works ??
Old Apr 21, 2003 | 03:32 PM
matty's Avatar
Alright it feels awsome through the gears above 5000 but I just want to insure its working in every gear properly...
I tried it today with the hood open in my driveway set at 3000 RPMS, reved it up to 3K, it opned alittle past 3K then let it go back down. I did that a few times and I noticed that it doesnt close till about 2300rpms on its way down after I let off the throttle..This may be caused but smaller tube I needed to use on the Vaccuum canister on the small nipple ?? It may be normal ?? or my vaccum switch may be malfunctioning (New Dawes Device)
anybody have a trick to actually see the aculator arm open while driving
-matt
Old Apr 21, 2003 | 09:31 PM
matty's Avatar
bump
Old Apr 21, 2003 | 09:42 PM
iansw's Avatar
Re: Making sure VI works ??
-matt
You could hook an LED from radioshack to the positive and negative on the solenoid....run it to your ****pit and then when it lights, the RPM switch is activating...
Old Apr 21, 2003 | 10:26 PM
xHypex's Avatar
You really should be able to hear the VI kick in. The resonance difference is pretty distinguishable.
-hype
Old Apr 22, 2003 | 05:09 AM
Confused's Avatar
Permanent Maxima.org Resident
do it on a dyno.
Old Apr 22, 2003 | 11:53 AM
matty's Avatar
ya I can tell a diffence in the way the car sounds...
Did you guys have to use a smaller size tube on the small nippl* of the vacuum canister, compaired to your vacuum source and your seleniod tubes ??
-matt
Old Apr 22, 2003 | 12:11 PM
Stephen Max's Avatar
Hey Ian, do you or any of you other SC'ed guys with MEVIs notice a difference in sound? I don't, other than maybe a very subtle change.
Old Apr 22, 2003 | 12:47 PM
AllGo's Avatar
Jay25 once said that he could hear the "tink" of the actuator arm bottoming on the intake frame. I can't hear it over my engine/s.c but the pull is very different from the suffocating feeling of the usim. I had the mevi in a box for about 2 months and contemplated installing it due to the rumored loss of torque. I wouldn't go back now for anything the pull in 3rd on the highway is great and even below 5k the engine revs more smoothly .
Old Apr 22, 2003 | 12:51 PM
Confused's Avatar
between my exhaust and a V1 a VI is like an ant... no noise difference.
Old Apr 22, 2003 | 01:12 PM
xHypex's Avatar
I could see how that's the case, but on a NA car without cams the intake sound/power is quite pronounced. With cams the VI resonance gets lost, and the power difference isn't very noticeable.
-hype
jerrod99_se-l
Aug 27, 2015 08:27 PM
Max8
Aug 20, 2015 07:20 PM
criminalslang810
Aug 16, 2015 08:12 AM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
