5th gen 6spd
Old Apr 21, 2003 | 04:26 PM
markargente's Avatar
5th gen 6spd
Since the 5th gens are also a vq, would it be possible to put their 6spd tranny into out fourth gens? That'd be hot
Old Apr 21, 2003 | 05:02 PM
JMAXIMA's Avatar
been asked tons of times, and from what i remember the 5th gen tranny will not match up to the 4th gen engine. also, the 4th gen gearing is tuned for the 3.0vq... it wouldn't be worth it to swap... except to say you have a 6spd 4th gen.
Old Apr 21, 2003 | 05:10 PM
johnvt1111's Avatar
i think a 2000 tranny would work on a 4th gen because they are basically the same engines except for the fact that the intake manifold is variable on the 2000 making the extra 25 or so horses....but what makes me curious is if a 2000 5 spd tranny would work on a 2k2 engine, just a thought
Old Apr 21, 2003 | 09:25 PM
Ninos_Maxima's Avatar
be the change u want2C
It should be feasibile, if a guy can take a Civic Tranny from a 5 Spd Si and swap it with the old old 4spd tranny and it works more than perfect, why not, The 2 motors are very close, and very simalar, It would probably cost a little but its well worth it in the long run, Max Speed increase by a lot
Old Apr 21, 2003 | 10:22 PM
clee130's Avatar
Old Apr 21, 2003 | 11:34 PM
d_warner's Avatar
Old Timer
Originally posted by clee130
I know clee. But hey, I asked this same thing once. If I could search, I'd go find it. Anyways, I think it came down to a computer issue. Since the tranny is also controlled by the computer, meaning you'd need a 2K3 computer. But since the 2K3 computer is nowhere near the same as a 2K or 2K1 or any 4th gen, it would be damn near impossible. You got to remember that the 3.5's are drive by wire. Meaining the computer controls the throttle body etc. The only way I see it, is to swap the 3.5, the tranny and a complete wiring harness to go along with it. From there, the only thing that should cause you problems is overall dimensions and other minor stuff.
GOOD LUCK
David
Old Apr 22, 2003 | 12:22 AM
johnvt1111's Avatar
GOOD LUCK
David
dave, i'm in the process of getting a 3.5 engine, wanna try and swap it for me
Old Apr 22, 2003 | 04:49 AM
We wont know untill someone tries, That thing about the honda was true, If that thing about the ECU is true cant you just reprogram the ECU?
MAXSE5SPD
Sep 17, 2022 04:00 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
dcam0326
Sep 18, 2015 04:52 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
