brighter corners
Old Apr 22, 2003 | 10:37 PM
deewanapaki's Avatar
brighter corners
how do i make my corner lights brighter so they actually look hyperwhite rite now even with piaa xtreme white plus bulbs they are looking halogen. please help me out
Old Apr 22, 2003 | 10:45 PM
danimsta's Avatar
check my site...
click how to
then click brighter corners..
its with pictures and everything
good luck!
Old Apr 22, 2003 | 11:00 PM
thx man i hope its the same for the i30
Old Apr 23, 2003 | 12:37 AM
99maximagxe's Avatar
dang thats all u have to do? cut off the lower nub of the bulb?? I thought u have to splice wires or something
Old Apr 23, 2003 | 03:29 AM
NismoVQ's Avatar
What I did was bend the metal of the connector of the harness on the section where the lower nub originally was. if you bend it outward enough, the nub will just be on the inside where the bulb is. I was going to cut the nub off, but i left my dremel at my friend's house. This way takes a lot less effort but works perfectly!
Old Apr 23, 2003 | 03:40 AM
willis's Avatar
My heroine
you can just cut the nub off with a nail clipper... it's really not hard
Old Apr 23, 2003 | 04:22 AM
97GLES's Avatar
don't forget to upgrade you fuse.
Old Apr 23, 2003 | 06:12 AM
Sorgasm's Avatar
Which fuse is it and what should it be upgraded to?
Old Apr 23, 2003 | 06:23 AM
MaxRocZ's Avatar
Wow...I can't believe it's that easy. Why does just cutting off that nib make them brighter though? Does anyone have a technical explanation for that?
Does the increased light intensity cause the bulb to burn out quicker too?
Old Apr 23, 2003 | 11:24 AM
97GLES's Avatar
parking light fuse must be upgraded.
i did this to my car over 2 yrs ago & i still have the same bulbs. i didn't even cut the nib off, just pushed the bulb in.
Old Apr 23, 2003 | 11:31 AM
funmax's Avatar
what's the fuse you upgrade to?
Anyone know how to make the signal light on all the time?
Old Apr 23, 2003 | 11:34 AM
95maxmadman's Avatar
Upgrade the fuse to what?
Old Apr 23, 2003 | 12:08 PM
hacim105's Avatar
Why would you upgrade the fuse? I have not had a problem with any of my lights. This is the first I've heard of this but if it's advised I might just do that.
Old Apr 23, 2003 | 01:08 PM
drewbowski's Avatar
funny ****
hahahah "drive around and get all the girls" hahahaha
Old Apr 23, 2003 | 01:11 PM
99Maxima5sp's Avatar
no fuse upgrade needed...
I was amazed myself how easy it was...
eric
Old Apr 23, 2003 | 01:44 PM
danimsta's Avatar
yeah its pretty easy, but i have a how to just in case some people are a lil skeptical
Old Apr 25, 2003 | 01:57 PM
n2o_matt's Avatar
Originally posted by danimsta
check my site...
click how to
good luck!
After that one screw you took out do you take off the whole corner?
I tried pullin it off but I looked between the car and the light and there was a metal strip blocking it. It looks like you would slide it side ways but I wanna make sure. Maybe you just have to force it, (even though that is against my religon, J/K.)
srry I've never done anything w/ lights (noob)
Old Apr 25, 2003 | 03:37 PM
markargente's Avatar
The nub itself is just to keep it in place. If you look under the bulb, theres two connectors. That is because these are dual filament bulbs. They way you're supposed to connect it only uses the less brighter of the two. You can't put it on the other way without cutting off the nubs because of the way they're set up. When you cut the nub, and switch the orientation, the watts will run through the connecter that is supposed to give it a brighter light
Old Apr 25, 2003 | 06:48 PM
DigitalTexan2u's Avatar
With the bulbs now producing more light...they're going to produce more HEAT...any problems with melting the housing?!
Old Apr 25, 2003 | 07:44 PM
Many people on the forum have had these for awhile, but none of had it melt. I'm not sure if it WILL happen, but i figure you dont have your lights on 24/7, so i think it would have enough time cooling down when you're not using it
Old Apr 25, 2003 | 07:45 PM
Just wondering though...I always drive with my lights on though.
Figured with summer coming, everything will be hotter.
Thanks!
Old Apr 25, 2003 | 07:47 PM
Thanks!
its up to you to always drive with your lights on, but also factor in how long most of your trips are, and how long its not in use. totally up to you
Old Apr 25, 2003 | 10:12 PM
Gen8888's Avatar
Does this work with '97 Models? It says that it is for '95-96 Models on the How To. but i have seen some people on the board that have 97+ and doing the cutting of the nub instead of splicing and soldering the wires. Thanks.
Old Apr 25, 2003 | 10:32 PM
BadKarma99-4spd's Avatar
on my 99 i cut the top nub with nail clippers and then put the bottom nub where the top nub used to go and got the same result(brighter corners). if your worried about the socket melting, they are easy to replace and cost $14.00 and bulbs are like $3(i should know i messed one up)
good luck
Old Apr 26, 2003 | 05:34 AM
good luck
thats what i did
Eric
Old Apr 26, 2003 | 08:10 AM
Juki5536's Avatar
Well I'm gonna get bright lights in the corners, wanna get them even with the XD5's I'm buying. Should I upgrade the fuse in the corners, like 97GLES said? And what fuse would I get?
Old Apr 26, 2003 | 09:01 AM
its not necessary
eric
Old Apr 26, 2003 | 10:47 AM
n2o_matt's Avatar
Help :confused:
Can any one give me more detaild instructions please? After I unscrewed the one screw and started to take out the light assembly i noticed it woulden't come out. Its all loose but i can see a small bolt that is holding it in place, how do i get to it? I have a 99', any one else have this prob?
Old Apr 26, 2003 | 10:50 AM
araffio's Avatar
You can also use a 1156 bulb, just cut off one of the nubs at the base...
Old Apr 26, 2003 | 11:32 AM
danimsta's Avatar
Re: Help :confused:
just give it a lil elbow grease, the metal thing thats holding in the light is just that, to hold it in, just it out, it wont be easy, but firmly take it out
Old Apr 26, 2003 | 11:42 AM
Ziggdout's Avatar
Took dan's advice and made my corners brighter.....looks great and it takes only 5 min. Its really gotta be one of the simplest mods out there!!! If you cant do it, do us max owners a favor and sell your car!!!
Old Apr 26, 2003 | 11:45 AM
KsuMax's Avatar
Cheesing away...
Orginally posted by Ziggdout
Old Apr 26, 2003 | 12:36 PM
Dasyce's Avatar
you MUST change the fuse, i didn't and then i fried the fuse and had to upgraded to a 10a fuse, when u fry the fuse, your brake lights won't work either, so if someone crashes into your back you'll know why
Old Apr 26, 2003 | 02:37 PM
white95max's Avatar
Where can you buy an upgraded fuse?
Old Apr 26, 2003 | 03:50 PM
It's not an "upgraded" one...he means one that will allow more current.
Instead of say...a 5A, or 7A...put a 10A in it's place.
With the lights being brighter, they will draw more current = more heat = a 5 or 7 amp "popping" or "blowing" whereas a 10 amp will be able to handle more.
Make sense?
Old Apr 26, 2003 | 04:04 PM
danimsta's Avatar
Make sense?
Old Apr 26, 2003 | 05:24 PM
n2oMike's Avatar
I had to grind the nubs on the bottom of the bulb down to get it back in there. I had to grind them down almost flush.
The thing that holds the lens in place was TIGHT! After taking the screw out and flipping the back part free from the metal flange, I had to insert a wide bladed flat screwdriver in there are lever out the 'pop' socket.
It took a good bit more than five minutes...
I haven't changed the fuse, but I took the car downtown and back to pick up a movie, and it hasn't blown yet.
Good Luck!
Old Apr 27, 2003 | 07:20 PM
Juki5536's Avatar
Ok, so where can I get 10A? Local parts store? Also, I noticed my lights next to the turn signals were real weak too (like my corners). Anyway I can make those brighter also?
Old Apr 27, 2003 | 07:22 PM
Wal-Mart or ***any*** other automotive parts store!
Just buy an assortment pack and have some various spares
Old Apr 27, 2003 | 07:27 PM
danimsta's Avatar
