courtesy nissan's front strut bar
Old Apr 23, 2003 | 01:53 PM
BigJayx23's Avatar
hi everyone... anyone know the torque spec for the courtesy nissan's front strut bar???? is it from the range of 43ft.lb to 58ft.lb??? im talking about the 3 14mm. nuts that mount right on top of the strut mount...
Old Apr 23, 2003 | 01:57 PM
sil SE's Avatar
bump for the question
plus, does anyone experience creaking noises from the bar rubbing against the hoodliner perhaps on turns?
Old Apr 23, 2003 | 01:58 PM
95maxmadman's Avatar
I want to say 30ftlbs. but i can't be sure
Old Apr 23, 2003 | 02:14 PM
BigJayx23's Avatar
well i cant say i have experienced any noise yet cuz i just got the bar but if there is i will let u know.. well from wat i read from the chilton manual without the strut bar the nuts are suppose to be torqued at 30 to 40ft lb. but now you have a strut bar there shouldnt the torque be increased.. to say about 40 to 50? correct me if im wrong...
Old Apr 23, 2003 | 02:31 PM
xHypex's Avatar
Correct. I always split the number to allow you some room for error. I torque to 35 ft lbs.
Don't ever go over the maximum recommended torque spec. The studs aren't designed for that amount of torque, so you'd probably break them. If you're worried about them loosening drive around for a while (~100 miles) and retorque to 35 ft. lbs.
-hype
Old Apr 23, 2003 | 02:57 PM
BigJayx23's Avatar
Thanx hype will do... just got confused with this other site... there was a site putting in a stillen front strut bar and they used 40 to 50ft lb. i think it was a 99 max or a 98max... o by the way... is there a rear strut bar for our car?
Old Apr 23, 2003 | 03:05 PM
xHypex's Avatar
Yeah Courtesy makes one and Stillen does as well.
-hype
Old Apr 23, 2003 | 03:06 PM
BigJayx23's Avatar
thanx for the fast response hype
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
MaxStock
Aug 14, 2015 10:01 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
