Rear Brake Lights!
Rear Brake Lights!
I have a dead brake light bulb and I just bought 1157 bulbs to replace it, but how do I replace them? There is no compartment in the trunk like Hondas (I'm used to Hondas - this is my first Nissan). The only compartment in the trunk is for the jack, and everything else has carpet bolted down. I think I have to take off the whole reflector thing, but how? It's a 95 Maxima GLE.
Thanks!
- Jatan
Thanks!
- Jatan
I believe that you have to remove part of the panel that is right behind the tail light, on the inside of the trunk. There are some twistie tabs and some other ones that you can use a panel tool to get off. You should not have to take the whole panel off, just loosen the part behind the tail light.
I have to remove those plastic bolts so that the carpet loosens? I'll post up the pics in about 6-7 hours (after I come back from school).
- Jatan
- Jatan
- Jatan
Originally posted by Turbo1er
Yeah, just remove enough of the plastic bolts to lift the carpet away from the taillight you need, then it is a simple latch on the back of the taillight to open to replace the bulb.
BUT the damn thing don't come off. I need to replace the one with that black rubber backing thing (the one all the way in the corner). I tried to take a pic, but the cheap digi cam took a dark pic and you cant see anything. But anyways, how do I take off the black rubber thing to get to the bulb? I tried with a screwdriver but no luck.
Huttig2009
09-25-2015 03:31 PM
JMag90
08-25-2015 09:17 AM
