Frankencar Intake Problem
Old Apr 24, 2003 | 11:42 AM
WOODYMAX98's Avatar
Ok first Frankencar never sent me the sleeve to connect the pipe to the MAF. So I went to Home depot and baught an adapter to connect them and everything worked fine. Then frankencar sent me the adapter peice and I put that on. But now sometimes my car just dies, It seems like it chokes and it dies. Why is that?
Old Apr 24, 2003 | 12:08 PM
maxspeed96CT's Avatar
The original VQ...
check if all of your hoses are connected good and check all the sensor plugs, try reseting you ecu also.
Old Apr 24, 2003 | 12:23 PM
sleepermaxima's Avatar
Yeah, I agree... It sounds like a vaccuum problem. You may also want to make sure that one of the hoses is not being crimped after you hooked everything back up.
Later,
D
Old Apr 25, 2003 | 10:19 AM
WOODYMAX98's Avatar
to reset the ecu all i have to do the same thing that is described for reseting the check engine light, right?
Old Apr 25, 2003 | 10:54 AM
That's how I do it.
Old Apr 25, 2003 | 11:33 AM
FLO_BOY's Avatar
Re: Frankencar Intake Problem
do you receive any codes?
also, check your MAFS wiring...
with your car running, give a GENTLE tug on the MAFS wiring and
see if your car dies on you...also, how's your fuel economy lately?
FLO_BOY
Old Apr 25, 2003 | 11:54 AM
WOODYMAX98's Avatar
I just reset the ecu, the codes came back 5 5 which means nothings wrong. My MAFS is on tight, and my mpg is also good. Just sometimes my car revs up when i start it then the revs drop and it dies.
Old Apr 25, 2003 | 12:01 PM
FLO_BOY's Avatar
time to clean your throttle body???
FLO_BOY
Old Apr 25, 2003 | 03:41 PM
WOODYMAX98's Avatar
How do you clean your throttle body?
Old Apr 25, 2003 | 03:56 PM
FLO_BOY's Avatar
Go here: Motorvate.ca
It's a great site!
FLO_BOY
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
