midpipe install problem
Old Apr 24, 2003 | 11:59 AM
Maxima 504's Avatar
i added a midpipe to my K&N cone filter. everything went smooth on the install. i took all the unnescessary stock stuff out, and put the midpipe on. when i went and took a ride i tried to gun it, and i couldn't go past 30mph. it seemed like the pedal was stuck, but i know it isn't. i know i hooked everything up rightwhere it goes. anyone know what could be wrong?? thanks.
Old Apr 24, 2003 | 12:19 PM
njmaxseltd's Avatar
The clamp is hitting your throttle linkage.
Look at the throttle linkage by the throttle body, you'll see it.
Old Apr 24, 2003 | 05:22 PM
Maxima 504's Avatar
thanks that worked i tried it again now i can go fast without any problem... but now the filter seems twice as loud. i know that a K&N filter is supposed to hiss, but this is really loud... my friend with a monsterflow filter isn't anywhere close to as loud... is this a problem?
Old Apr 24, 2003 | 06:10 PM
Ceasars Chariot's Avatar
Old Maxima Legend
are you kidding ? this is great !!
Old Apr 24, 2003 | 06:48 PM
MAXSRB's Avatar
Sounds like you have a broken johnson rod....Its the peice of metal inside your intake manifold....you have to go to a mechanic to get it fixed, but its not that big of a problem....just dont drive your car on one way streets and the engine should be fine.
Old Apr 24, 2003 | 09:56 PM
Maxima 504's Avatar
how much does a johnson rod cost to replace, and will it cause anydamage besides the loud hiss???
Old Apr 24, 2003 | 11:03 PM
MAXSRB's Avatar
lol man i was just joking about the johnson rod....but if you have the hissing while you are idleing then that most likely means you have an leak in the intake somewhere. That means the air is getting out somewhere and your intake is not totally sealed up. You will lose hp so just listen and try to find the leak and patch it up somehow
Old Apr 24, 2003 | 11:05 PM
Maxima 504's Avatar
but i only hear the hissing from the intake and nowhere else. my boy told me that K&N's are louder, and monsterflow filters are more insulated. could this be, and would it harm anything, cause if so i will take the midpipe off. thanks
Old Apr 24, 2003 | 11:12 PM
MAXSRB's Avatar
I ride around with a K&N without a midpipe like you once did. I am currently making my custom midpipe and the only worry i have is that the filter itself may have a leak in it because i never really had anything holding up the intake assembly. The filter was just resting on the fender well, and over time just keeps banging up against the car. Try to put on another filter (possibly ask your friend to test fit his if it fits so you can find out wheter or not your K&N has a hole in it anywhere. If the hissing is still there even with your friend's filter than you have an intake leak somewhere in the midpipe area.
Old Apr 24, 2003 | 11:15 PM
Maxima 504's Avatar
go idea thanks man... i also had my filter resting on the fender... so i will try this out and if i have the same problem, then its a leak.. thanks for the help. peace out
Old Apr 24, 2003 | 11:19 PM
Maxima 504's Avatar
and one more thing, is this possible leak going to cause any problems you think?
Old Apr 25, 2003 | 12:02 PM
Maxima 504's Avatar
bump
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Tha'-Max
Aug 30, 2015 01:14 AM
kirkhilles
Aug 8, 2015 10:53 AM
