Wrong Fuel filter and PCV Valve ?
Old Apr 24, 2003 | 06:28 PM
Pearl99GXE's Avatar
I recently bought some parts from The Parts Bin.com. The air filter and brake pads were fine. The PCV valve look different from the one that was on the car. I was bigger and blue but still fit. If it is the wrong one, will it have a bad effect on the car?
Also the fuel filter was a Bosch #71650 F00E160056. It looks a little smaller than the one on the car. I did not change it yet. I need your expert opinion on wether it is the right one or not and if not, will it have an adverse effect on my performance?
I am not a mechanic. I'm just an Accountant who likes to (try to) do his own work on his car.
Thanks for your help
Jim
Old Apr 24, 2003 | 08:14 PM
markargente's Avatar
Re: Wrong Fuel filter and PCV Valve ?
Jim
As for pcv, as long as it fits its fine. mine is blue too.
Old Apr 25, 2003 | 10:11 AM
ny96max's Avatar
as long as Bosch calls for those part numbers im sure you will be fine. My Fram Fuel filter was a drop bigger then my stock one when i changed it.
Ant
Old Apr 25, 2003 | 11:34 AM
vipervadim's Avatar
I like Maximas
i have a 300zx fuel filter works great, i don't think it should matter too much as long as it has the accomodated fuel flow and it filters well. only if you have lots of boost and are running more fuel via a better pump and faster injectors, then you might have a problem.
Old Apr 25, 2003 | 01:22 PM
Pearl99GXE's Avatar
It has no flow markings. Is it safe to assume that the smooth rouned side is the in part and the flat end with the seem is the out end?
Thanks again. I love you guys.
Jim
Excalibur23
Oct 13, 2015 04:33 PM
JoshG
51
Sep 21, 2015 10:41 PM
iamute
Sep 20, 2015 05:22 PM
bumpypickle
Sep 20, 2015 08:22 AM
aminus21
Sep 12, 2015 04:53 PM
