Clock restarts
Old Apr 25, 2003 | 07:53 PM
CaLSoNiC
Clock restarts
Just randomly my clock will reset itself? Anyone know whats wrong?
Old Apr 25, 2003 | 09:04 PM
Max97SE's Avatar
I had the same problem. It got worse and then the clock failed altogether. I found a thread back in the beginning of April. I found that the connector block on the clock board was loose, resolder it and fixed my clock...
http://forums.maxima.org/showthread....hreadid=188414
Old Apr 25, 2003 | 10:42 PM
Sway1331's Avatar
have you disconnected the battery recently? sometimes when you hook it up again the computer gets messed up i forget the correct way to fix this. it happed on my 3rd generation a few times never had it happen on my 96 so im not sure if this could be your problem
Old Apr 26, 2003 | 12:57 AM
CaLSoNiC
It never "cuts" out. It simply will just go back to 1:00
ANd no I havent disconnected my battery in some time.
Old Apr 26, 2003 | 06:49 AM
Max97SE's Avatar
It's the start of the problem. The clock momentarily loses power due a failing solder joint and resets the clock. Mine went for a while like that, then started to be intermittent on / off, then finally remained off. The solder joints (typically on the 4 pin power block) fail over time. The temperature will affect it also as the metal contacts expand and contract.
hayne
Oct 5, 2015 11:53 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
msellas
Sep 23, 2015 09:16 PM
markevans999
Sep 10, 2015 04:29 PM
