Help, This **** Might Get Me Hurt!!
Old Apr 26, 2003 | 10:17 PM
imstuckherenow's Avatar
ok, my brakes will jus go out for no reason. i can put the brake pedal almost to the floor and it feels like the pads are jus barely catchin enough to slow me down, not good if i need to stop in short distance. but then i can go 20 ft down the rd and they fine. usually if i pump the pedal,it will work again. is the this master or slave cylinders or anyhing like that? i need to kno wtf is goin on!
Old Apr 26, 2003 | 10:21 PM
sandman1098's Avatar
That would be a good place to start.... look for leaks and things like that......
Old Apr 26, 2003 | 10:23 PM
i have and found nothing, even been keepin an eye on the brake fluid. hasnt gone down any!
Old Apr 26, 2003 | 10:24 PM
mtrai760's Avatar
'Trynna' is not a word
Re: Help, This **** Might Get Me Hurt!!
sounds like the brake master cylinder. I had one go out in another car, and it would do the same thing. Get it fixed ASAP!
Old Apr 26, 2003 | 10:26 PM
how much this gonna cost me? is there anyway to rebuild it or somethin or at least do it myself?
Old Apr 26, 2003 | 10:31 PM
mtrai760's Avatar
rebuild? no, you can't do it, trust me. You can replace it yourself. You have a haynes or chiltons? try courtesy nissan, www.courtesyparts.com or try calling them, they might give you a cheaper price if you mention the .org. Most local car parts places will require you to turn in your old one when you change it out, and will require a parts deposit until you do, and you will recieve a rebuilt one, not a new one. You won't notice a leak if yours is bad, the seals just begin to leak and won't hold pressure. You will have to bleed your entire brake system once your done, so if your not comfortable doing that, then I would take it to a proffesional, its not worth your life. I strongly recommend not driving the car until you get it fixed, again, not worth your life.
Old Apr 26, 2003 | 10:34 PM
its not the the point i cant stop, but i will do it soon as i can. how much will this cost me?
Old Apr 26, 2003 | 10:35 PM
oh, btw i am and idiot and would like to kno where the master cylinder is (i dont kno **** bout maximas engine)
Old Apr 26, 2003 | 10:53 PM
The master Cylinder is on the drivers side of the engine bay, up against the firewall, it has a white plastic resivoir and a black cap on it
Old Apr 27, 2003 | 12:40 AM
ßaller's Avatar
I agree that it appears to be the Master Cylinder. I remember when mines went bad that I had to double pump my brakes for it to work properly, if I pumped the brake once I would have to pump it hard and almost to the floor.
- ßaller
Old Apr 27, 2003 | 06:38 AM
njmaxseltd's Avatar
The Master Cylinder in my Honda died the exact same way. Every now and then my foot would sink to the floor.
It was an experiance getting it out of NYC the day it happened!
Old Apr 27, 2003 | 11:26 AM
slizan99's Avatar
have you thought about bleeding your brakes?
Old Apr 27, 2003 | 11:30 AM
TylerBorg's Avatar
That has to be an interesting experience driving lol
Old Apr 27, 2003 | 03:07 PM
its not really any different, its jus every once in while my foot will go to the floor and i have to remember to pump it real quick. scared the fock outta me the first time it happend tho
Mad Jap
Mar 12, 2001 12:12 PM
Empz
Feb 12, 2001 02:10 PM
primeevil711
Jan 27, 2001 01:34 PM
MidnightSpeed53
Nov 20, 2000 12:33 PM
