where the *&*#@! did my oil go?
Old Apr 30, 2003 | 08:58 AM
Sven Veets's Avatar
Well, my oil level has gone from F to L in 3 weeks. First of all, does anyone know how much oil it takes to get from full to low?
There are no oil spots on the driveway, and I'm not burning any oil, as far as I can tell. Would the best thing be to take it in for a pressure test?
Old Apr 30, 2003 | 12:19 PM
Zirafa's Avatar
Re: where the *&*#@! did my oil go?
"...I'm not burning any oil, as far as I can tell..."
How do you tell?
If "...There are no oil spots on the driveway..." then I think you most likely are burning some oil. I may be wrong but just my $.02
Old Apr 30, 2003 | 12:29 PM
Sven Veets's Avatar
There is no burning oil smell, and no white smoke at all, so it doesn't seem likely to be burning. The real question I still have is this: How much oil have I lost going from the the top of the "full" reading on the dipstick to "low" ?
Old Apr 30, 2003 | 12:36 PM
Jeff92se's Avatar
I'm needing a caw
1 quart. Let it sit overnight and check it on a level surface before starting it up
Old Apr 30, 2003 | 08:22 PM
mkan's Avatar
I've been having oil problems too. I have a '95 SE w/ 152k miles on it. I'm burning about a quart every 750 miles. I'm not sure what the problem is, but I'd really like to figure it out because I'm sure it's not good for the engine!
Old May 2, 2003 | 08:42 AM
TooMAX's Avatar
Oil burns blue, water comes out white. It could be venting out through the pcv valve - have you replaced that lately? I bet your intake will need to be cleaned too. Also, high revs and hard driving will consume more oil than 'normal' driving.
Old May 2, 2003 | 09:14 AM
Radiohead's Avatar
My friend had this problem also with her Prelude. She would lose 2L of oil in under 1000km
A mechanic "theorized" it was her vavle seals were at fault... so it wasn't good.
Maybe someone can verify, but a leak down test might show where the leak is & if it's a valve or ring that's faulty?
Old May 2, 2003 | 09:34 AM
Miasma's Avatar
leakdown test is a very good thing to do on any engine. i should get one done too. see my other thread: vanishing oil.
Old May 2, 2003 | 10:44 AM
MaximaMoJo's Avatar
What is a leak down test? How is it performed?
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
