cut coil on Progress Springs?!?! HELP
Old Apr 30, 2003 | 05:08 PM
nismoluvr's Avatar
I am wondering if anyone has cut a coil off of the progress springs?? I went from Ground Controls to Progress and the drop doesn't do it for me. If anyone has cut a coil, how does it sound (any clinkidy clanks), and does it stay seated well??? Thanks!!!
Jason
Old Apr 30, 2003 | 07:18 PM
imstuckherenow's Avatar
i got a set of intrax springs with 1 coil cutt off both the front since the back ones tend to sag. they ride fine, no noises or anything like that.
Old May 1, 2003 | 01:45 PM
nismoluvr's Avatar
Anybody do it to the progress springs?? Do you cut a coil off the top or bottom?
Old May 1, 2003 | 03:57 PM
Tri-lite's Avatar
I would also like info on this ... I have a set of maxspeed that I would like to cut.... does it also make the spring stiffer or softer?
thx
Old May 1, 2003 | 06:02 PM
makes it lower, that bout it. if u want stiffness u need to be lookin for shocks/struts
Old May 1, 2003 | 06:09 PM
Max Noob's Avatar
im gonna cut half a coil off just the front maxspeed springs to even out the gap..im pretty sure u cut the top. for your progress springs, cutting a whole coil may give you problems cause the spring gets alot shorter..ive heard stories of the spring popping out everytime u raise your car to change oil, rotate tires or jump a cliff. good luck..tell us how things turn out..you'll prolly need camber kit for sure.
MaxLvr21
Oct 17, 2015 12:11 PM
RealityCheck
Oct 2, 2015 06:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
zmcneely13
Sep 26, 2015 02:26 PM
