Backfire with Injen.....Solved!!!!
Old May 3, 2003 | 06:06 PM
ecapati's Avatar
Recently installed an Injen CAI on my 99 SEL, and love the new acceleration and the great sound. Then started hearing a backfire/misfire around 3k – 4.5k RPM all the time. 5-10 popping sounds, loss in acceleration, then engine clears and pushes to redline. 2-3 more pops when the tranny shifted. No codes, car has 50k miles, always 93 – 94 octane, concentrated STP fuel injector cleaner every oil change, cleaned TB, changed fuel filter, re-checked for air leaks on CAI and still no change. Actually got worse when the air temp was below 50 degrees.
Installed new NGK Platinums several days. Front set first, took a test drive, and misfire occurred intermittently. Installed the rear set today and stomped on the throttle and WOW, instant improvement in acceleration. Backfire was GONE!!!!! Problem solved.
Two question though, all the plugs looked normal but the rear plug on driver side had a white glazing around the nut and isolator area. What is causing this condition on the spark plug? Anybody else experiencing this with the same rear plug?
FYI, bought plugs from www.xterraparts.com for $51.48 plus shipping. This happens to also be a sister site of www.courtseyparts.com which charges $57.00 for the same set for their Nissan Maxima parts.
Old May 3, 2003 | 10:44 PM
2KxSEx's Avatar
It's probably your ignition coil in the rear w/the hot spark plug.
Old May 3, 2003 | 11:58 PM
JsL's Avatar
JsL
I noticed my rear plugs were nastier also. I gained more low end when I changed my plugs, I just have to get around to changing the fuel filter now
Thats a good post for someone's first time. Welcome!!
I bought my platnum plugs off ebay for less than 35 shipped to my house!!!
Old May 4, 2003 | 09:44 PM
BOZOnPJs's Avatar
i never experienced that problem with my injen.. hopefully wont either.
Old Jul 16, 2009 | 01:47 PM
KRRZ350's Avatar
Just experienced this problem, swapping out the beat up bosch platinums with some Nissan plugs cured it.
Old Jul 16, 2009 | 02:32 PM
Shift_Nismo's Avatar
I was wondering why my car was making that sound, guess ill change the plugs, and see if it goes away
Old Jul 16, 2009 | 03:15 PM
96nismoSE's Avatar
way to bump an old a$$ thread dude! naw just playin.
Old Jul 16, 2009 | 03:16 PM
Product_Of_Korea's Avatar
Just wanted 4000 posts
Old Jul 16, 2009 | 04:00 PM
Quickywd01's Avatar
Just curious; I thought the injen "cai" doesn't make power on our cars? I emailed injen about it but they never responded.
Old Jul 16, 2009 | 05:14 PM
pmohr's Avatar
No more Maximas...
It doesn't, really.
Old Jul 16, 2009 | 09:35 PM
JtzMax's Avatar
Whatchyou say?
I agree, it doesn't do much, but it sure sounds good! lol
Old Jul 17, 2009 | 09:45 AM
Do this to your customer for running Bosch plugs in the Maxipad ....
Old Jul 17, 2009 | 04:29 PM
KRRZ350's Avatar
It would probably break his heart, in addition to this problem I took care of.... SEVEN dtc's! I imagine I'm his new best freind.
Old Jul 17, 2009 | 11:21 PM
hot_wax_tree's Avatar
Originally Posted by Bamfy98
lol yea... $250 for 3hp and an amazing sound.
or you can take the easy way out and just get a plate and filter from oreily for 20 and get the same sick sound.
oh and that popping is called back fire and typically that means you are running lean(to much air in your mixture) and a white plug is a good sign of running to lean. and vise versa is black plug=to rich.
jake
Old Jul 18, 2009 | 01:36 PM
defiance's Avatar
If black spark plugs mean your running rich and white means your running lean, what does brown plugs mean ? BTW they were bosch platinnums I just pulled out of the car.
NJK ALL THE WAY
Old Jul 18, 2009 | 03:34 PM
dx_man's Avatar
Brown means you are running like crap.....sorry bad joke...
Old Jul 18, 2009 | 10:14 PM
foamypirate's Avatar
Tan/brown is just about right.
Old Jul 18, 2009 | 11:06 PM
Blackwind's Avatar
it means you get your plugs from fredrics of hollywood.
Old Jul 18, 2009 | 11:19 PM
slow_yota's Avatar
hehe..made me chuckle.
Old Jul 19, 2009 | 12:23 AM
Yeah youre right. But why does injen have a meaner high pitched sound than a short ram? Is it because the sound of the VQ echos through the long piping?
I think that if you are getting into it that much you are either a good musician or should start being one cause you are getting way to deep into a simle little part I think you should leave it be at the cool noise any intake makes.
kapeesh???
Jake
Old Jul 19, 2009 | 12:24 AM
NGK's all the way. I have found problems with anything but.
Old Jul 22, 2009 | 10:09 PM
LCC.MaX's Avatar
would you get more of a power gain from the intake if you had a y pipe and a catback?
Old Jul 23, 2009 | 11:18 PM
Flava_24/7's Avatar
Boosted Panda
Y pipe is the only gain...
msellas
Sep 23, 2015 09:16 PM
Viking155
Mar 4, 2004 01:18 PM
ICONOCLAST
Mar 7, 2002 02:28 PM
NotNew!!NewSN!!
Jan 27, 2002 10:13 PM
