Help! New noise comiing from Front Driver's side corner while driving
Old May 4, 2003 | 09:57 PM
Vesaijan's Avatar
Hey guys, I've noticed this new noise that my car is making while driving. It is locallized to the Front driver side wheel/suspension area.
It sounds like a moderately loud click and only occurs when I do any of these three things:
1.) Hit the brakes and come to a full stop
2.) Start moving from a stop
3.) Turn right
It only occurs sometimes (not every time I perform any of three actions), but is definately associated with these three.
I took a look at the suspension and everything looked ok; I thought that it might be the upper strut bearing, but at a stop I can turn the wheel from lock to lock without any unusual noises.
Anybody got any ideas where I should start looking for this "suspension mouse" before I shell out the big bucks to have a mechanic look at it?
RL
Old May 5, 2003 | 01:17 AM
maximaseefu's Avatar
wheel bearing?
Old May 5, 2003 | 04:49 AM
thanpto's Avatar
If you have a FSTB, it could be that.
Old May 5, 2003 | 04:51 AM
Vesaijan's Avatar
Hmmm...I do have an FSTB...I'll check it out, but I am concerned that it might be the wheel bearing. Anybody know how much these cost to replace?
RL
Old May 5, 2003 | 06:17 AM
95GreekMaxSE's Avatar
does going over a bump affect the noise at all such as a rattle or a squeak???
Old May 5, 2003 | 08:22 AM
because the wheel bearing has to be pressed out and in, I just went to the junkyard and bought the entire hub assembly and replaced it. Did it a couple months ago, about a 3 hour job.
Old May 5, 2003 | 08:28 AM
Vesaijan's Avatar
Can't really tell because my whole car rattles and squeaks...(gotta love aftermarket suspensions)
The sound is a very distinct click and usually associated with the three things i listed. I think that it might be the spring isolators, but haven't had time to crawl under there and investerate. So far though it looks ok and the noise has not been a problem in the past (NB I just re-did my shocks in December, so if the spring isolators were a problem, i suppose they would have come up then).
How can I tell if it's the wheel bearing or not?
RL
Old May 5, 2003 | 08:35 AM
cam_honestiam's Avatar
Check CV joints/boots. If a bearing is bad, this might be shot as well...
Old May 5, 2003 | 08:58 PM
krbga's Avatar
"Clicks" usually mean CV Joint.
http://www.motorvate.ca/mvp.php/400
http://www.motorvate.ca/mvp.php/401
Old May 5, 2003 | 09:21 PM
Vesaijan's Avatar
Hey, thanks for you help guys. I'll actually get a chance to look at it this week (school is almost out thank God).
I noticed something else though. The click that I hear makes me think light switch. When I'm at a stop, it'll click once, but not again, even if I slow down a bit and then hammer the gas (think of the light switch being on).
When I am decelerating to a stop, i get a click when I brake hard, but if I reaccel a bit and then hit it hard again, no sound.
So I think that it may not be the CV or bearing since it's not a continuous sound. Where is Daniel B. Martin when I need him? lol
RL
Old May 5, 2003 | 10:14 PM
sandman1098's Avatar
Does it make noise while going over bumps? If it does, it may just be the upper strut bearing..... But I may be wrong though....lol
Old May 6, 2003 | 04:24 AM
Vesaijan's Avatar
Sometimes yes, sometimes no. I think its time for a new car...(jk)
RL
Old Oct 8, 2010 | 09:08 PM
kel456's Avatar
did you find the problems with the clicking sound when brake?
kingw323
20
Oct 21, 2015 08:36 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
erniel
Aug 8, 2015 09:32 AM
dauntlessmax
Aug 5, 2015 10:29 AM
BassAddictJ
Aug 4, 2015 11:38 AM
