Door Alignment Adjustment
Hey All,
Trying to adjust the drivers side door, so when it closes the door sits flush with the rear door. Does anyone know how to go about this? I was looking at the lock latch attached on the piler, but it looks like it has no room for adjustment .
On that same note, aside from spraying lube on the hinges/black plastic guide, is there any other adjustments you can make to the doors to make them easier to open and close.
Thanks in advance for any input!!!
Biz
![bonk](https://maxima.org/forums/images/smilies/bonk.gif)
Biz
You can move the latch on the door jam. Just loosen the mounting screws a little. Then you can tap the latch into a different position using a hammer & screwdriver. The latch will move about 1/4" in both directions.
That's how I did it.
No grease will ever remidy the slow back door problem. You need new 'door checks' as nissan calls them part # 82430-51U00. They are prety cheap I think mine were $14 each. Not too difficult to install either, now door closes and opens with the greatest of ease.
2¢
(_8*(l)
2¢
(_8*(l)
The door alignment was off when I bought the car. The door had been replaced/fixed per a accident with the previous owner. And now with the door closed, it sticks out a little less then 1/4". Figured if I could adjust either the striker or lock mechanism within the door by a 1/4" then I could realign the door to close flush.
Biz
Biz
i got in a crash -_- and now we fixed it but the door is slightly out of alignment and when i drive i hear the wind leaking....
when i push on it i can still make it go in a little i think its a bit more than 1/8 of an inch so how do u adjust it exactly????
tarun900
19
12-20-2021 06:57 PM
