Brake pedal travels to floor
Old May 6, 2003 | 11:31 AM
ALAC397's Avatar
Hey guys I just changed all 4 rotors and pads and bled the entire system and the brakes work well (no spongy feeling) . However I notice that if I press hard enough the brake will reach a point where it can go no farther as if bottomed out on the floor. Is this normal?
Note- I had observed this before I did the brakes and thought that it was secondary to thinned rotors and worned pads. So has anyone else noticed this?
Old May 6, 2003 | 11:44 AM
njmaxseltd's Avatar
So is the pedal sinking to the floor or just stops because you've reached maximum braking velocity?
Old May 6, 2003 | 11:45 AM
Entropy's Avatar
Maybe I am not understanding your question.
If you press hard enough, the pedal will have to stop eventually. You are dealing with solid objects and hydraulics... there is a finite amount of travel involved.
If your pedal is, in fact, hitting the floor... then I would start suspecting a bad master cylinder.
Old May 6, 2003 | 12:00 PM
NotNew!!NewSN!!'s Avatar
there has to be a leak or a bigggg pocket of air somewhere. My brakes usually will maybe make it halfway to the floor
Old May 6, 2003 | 01:04 PM
lefty
I think what he is saying is that when he is stopped..i.e. comes to a red light and initially stops....his brakes work fine. But when completely stopped, if he continues to had more foot pressure, the pedal is stiff but can eventually feel a hard end feel which is probably the floor.
I have this also in my car.
Anyone else?
Old May 6, 2003 | 01:05 PM
95GreekMaxSE's Avatar
dont worry...you are ok
Old May 6, 2003 | 01:57 PM
Maxima95Tuner
I have it too... it's fine.
Old May 6, 2003 | 04:05 PM
ALAC397's Avatar
Actually it's just as Lefty described. Thanks! I'm glad to know I'm OK.
Old May 6, 2003 | 04:27 PM
klymkow's Avatar
I've never heard of the pedal going to the floor unless there is a problem somewhere - i.e. leaky master cylinder, leaking caliper(s) or even a brake line starting to leak (due to corrosion), leaking brake hose, etc.
Anyways, I've never had one go to the floor unless there's a problem.
Tim
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
