GeForce ECU
i just won an ebay auction....my mechanic said i needed a new ecu cause of a problem ive been having so it works out good...and even if it doesnt fix my problem i could probably make most of my money back by selling it
Originally posted by I30tMikeD
Originally posted by 97MaximaSE
what i meant to say was normally when your check engine light is off the ecu forces the car to run rich cause something is wrong.....unless your rear o2 is shot then it doesnt really make a difference cause all it does it monitor the cat
Originally posted by slammed95
No, the check engine light does not affect the fuel maps at all. Only if the ecu detects certain sensors are bad will it richen the fuel mixture.
I have a 95 and have had the CEL since I installed my G-Force ECU. The most noticable difference is at around 3k rpm+. I pulls hard!
Theoretically gas mileage should improve, your engine is making more power and burning less fuel, aka running more efficiently. But when you have an ECU you tend to floor your car more so that kindof hurts gas mileage. Anyhow, the biggest gains from an ECU are from probably 3000-5000 rpm. You will like it.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
