Anybody with a bad antenna reception after replacing their stock headunit
May 6, 2003 | 10:36 PM
I replaced my factory Bose HU with a Kenwoood DPX 6020 in my 98 maxima and everything is fine but the antenna signal is lower than what it was when I had the factory HU in. If anybody could help that would be great.
May 6, 2003 | 11:15 PM
UM....did you plug the external antenna connector back up?
May 6, 2003 | 11:36 PM
You probably needed and used an ANTENNAE ADAPTOR, it has two ends... one is the primary antennae and the other is the defroster one. Usually the defroster one has a female end but not always.
Try the other one (primary antennae) and see if it is better.
May 7, 2003 | 03:02 AM
no its normal... aftermarket head units will never be on par with stock decks on reception. This is across the board with all stock units and all aftermarket decks.
