Well first of all god bless any one of you that takes on all the questions I have in this post.
Ok here we go:
1. I'm getting a squeeling sound from the left side of the engine where the UDP and the belts around that area. I squeezed my hand in there and felt one of the belts, it felt very rough like sand paper, I assume this means it is time for new belts. So this sound is mosty likely coming from these worn down belts right?
2. If this sandpaper feeling and loud sound means it is time to replace the belts I might as well, considering my mileage 100k KMs, replace all the belts there are. So I need all the part numbers for all the belts in the engine. I have an Unorthodox Racing UDP to be installed at the same time, and CustomMaxima.com had these part numbers for these belts
Alternator & Water Pump: 1995-02 Gates # K060408
Power Steering: 1995-02 Gates # K040292 If this one does not fit then try: Gates # K040300
So does anyone know what other belts I need, and if possible the part numbers as well.
3. My passenger side window is making a loud squeeling (squeeling sems to be common with my car right now) when it is going up and down. I remember hearing something about putting silicon on the window to fix it, but I can't remember. What should I buy to fix this? And how do I apply it? Do I put it on the window when it is up? Do I squeeze it into the slot where the window goes, do I do this with the windows up or down?
Sorry for all the questions, but any help would be great. Thanks again guys and girls.
- Steve
Ok here we go:
- Steve
