Power Steering
Old May 12, 2003 | 10:00 AM
davemax's Avatar
Power Steering
How do you know when your power steering is going out the door???
Old May 12, 2003 | 10:33 AM
s0ber's Avatar
put up your windows turn off your ac and turn the wheel if you hear noises its going bad :P I just changed my pump... no more noises now..
Old May 12, 2003 | 10:39 AM
davemax's Avatar
When I installed the Poly Bushings on my front sway bar I also emptied out the power Steering Fluid from the reservoir. Then I put in synthetic fluid mixed in with what ever was left in the hoses and system. Then I turned side to side to get out the air of the system. Now in the morning, the steering is sticky until I move the wheel a few times. Is it the synthetic fluid mixed with the factory fluid or the bushings have sand around the grease that was used?
Old May 12, 2003 | 04:22 PM
krismax's Avatar
Father of the 00 VI
If it does go or is going i may be able to sell you mine soon.
Old May 12, 2003 | 10:27 PM
† ErV †
when my steering rack was leaking and basically loosing it, it had reduced pressure (a tad bit tougher to turn the wheel) and i noticed the wheel buckling at road bumps and rough ground. like big time. hm my current rack makes all sorts of noises. i just take them as normal
lowpost99
Oct 26, 2025 06:53 PM
Fbana41
Aug 29, 2016 12:18 PM
rbarnes
Dec 31, 2015 06:29 PM
fastcarny
Oct 12, 2015 07:06 AM
homewrecker
Sep 24, 2015 07:01 PM
