DROP with 235 tires READ! please
Old May 12, 2003 | 08:11 PM
Max Noob's Avatar
i currently have 17x7 g35 wheels with 225/50/17 tires on them. the width makes the tires flush with my fenders.(not the wheelgap) im looking for 235/45/17 tires soon but i think those will protrude out past the fender. after my drop.i think it will rub on bumps. anyone else ever have these probs.? the rear end seems to be ok. i think the maxima wheel stance in front is larger.. or fenders flare out a lil more in the rear.
Old May 12, 2003 | 08:37 PM
madmax97's Avatar
I have 235/35/19 with sprint/kyb no rubbing no nothing. They dont stick out side wise and gap is nice finger to 2.
Old May 12, 2003 | 09:06 PM
I30tMikeD's Avatar
Re: DROP with 235 tires READ! please
Should be fine.
Old May 12, 2003 | 09:12 PM
99Maxima5sp's Avatar
my friend craig has 245-40-18s tires (craig mack) and it doesnt protrude or rub, and it is lowered..
Youll be fine...
Eric
Old May 12, 2003 | 10:02 PM
1996blackmax's Avatar
I thought it was not recommended to run 235/45/17 tires with 7" wide rims. It may be different for different tire manufacturers. I once contacted Yokohama about this, and was told by them that they do not recommend this setup due to the rim being to narrow for the tire. I went back to Discount Tire with the info in hand and got a new set of 17X8 from them and gave them back the 17x7's.
Old May 12, 2003 | 10:14 PM
I30tMikeD's Avatar
Re: Re: DROP with 235 tires READ! please
Most won't recomend it. I wouldn't do it. But many do w/o any problems.
Old May 12, 2003 | 10:50 PM
drewm's Avatar
Re: Re: Re: DROP with 235 tires READ! please
I'd think that the only problem you'd have is a weird "cupping" effect of the tire.
With the rim being too small, you'd have a "U" looking tire with less of the tire's sides making contact with the ground. Also with a small rim you will generally have more sidewall flex due to the tire not being as stretched out.
When the rim is too big, you'd have a "W" looking pattern with the middle of your tire bowing up in the center because the sides are stretched out, leaving you with less contact patch in the center of the tire.
But it all depends on how the tire was designed.
Old May 12, 2003 | 11:46 PM
Max Noob's Avatar
ahha.nice..im getting like 50/50 bad good responses.. probably gonna stick with 225 or 215's and save some gas.i dont plan on tracking or autox ever..just for looks and personal driving pleasure with the added ability to take a turn hard if i ever felt the need. what would u guys say.. higher qulity performance 215 or 225 or slightly lesser performance 235's?(cause they tend to cost more) its a 7 inch rim remember.
Old May 13, 2003 | 07:01 AM
I30tMikeD's Avatar
Go with the 225's. you can probably find a 225 that has almost the same tread width as a 235.
Old May 13, 2003 | 01:58 PM
Max Noob's Avatar
cool..got 225/45/17 kuhmo 712's..not the best tire ever but its pretty good.. price was excellent.. 105 per tire balanced, mounted.
Old May 13, 2003 | 05:04 PM
See if Yoko offers AVS ES100 tires in that size, WAAAY better than Kumhos and for the same price...
Eric
Old May 13, 2003 | 05:16 PM
WizzaMax's Avatar
I run 235/45/17 on my 7 inch wide rims...sue me...but I like and am keeping them.
Old May 13, 2003 | 08:57 PM
96BLUMAX's Avatar
Yeah people get away with 255s. No prob with 235.
The Frye
Sep 2, 2021 11:03 AM
MR2 T'd
Jul 9, 2021 05:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
dcardello
Sep 3, 2015 11:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
