'how to' on brake install?
Old May 13, 2003 | 07:26 PM
aznsap's Avatar
hey, im gettin brembo rotors, axxis mm pads and ss lines. i suppose i'll be changing my brake fluid also. is there a 'how to' on this somewhere? i dont' even know how much brake fluid to get.
Old May 13, 2003 | 07:31 PM
matty's Avatar
Chiltons and Hayes manuals both have good write ups on break jobs...
-matt
Old May 13, 2003 | 10:04 PM
D1NOnly34's Avatar
This site is like a chapter from the max bible..
http://www.motorvate.ca/mvp.php
Old May 13, 2003 | 11:29 PM
aznsap's Avatar
hey awesome. thanks. what does that shield behind the rotor do? can you remove that?
Old May 14, 2003 | 05:47 AM
StygianMax's Avatar
It's a dust shield. I think the wheel hub has to come off first. Then you need to bang it off. It looks like it's force-fitted in place.
Old May 14, 2003 | 08:46 AM
D1NOnly34's Avatar
Hmmm, either my dust shield sucks, or my brakes get real dirty, cause my rims are ALWAYS dirty and dark =(
Old May 14, 2003 | 08:50 AM
StygianMax's Avatar
I think the dust shield is to reduce dust/mud/crap on the rear face of the rotors. When you refer to "brakes get real dirty", do you mean the inside face of the rotor (or calipers)?
Old May 14, 2003 | 09:15 AM
D1NOnly34's Avatar
well, not the rotor, just the brakes, but they have been like trhat for a while. Basically what I meant is that whatever it is, gets my rims dirty real fast.
Old May 14, 2003 | 11:37 AM
StygianMax's Avatar
Some performance brake pads dust up more than others. If there's a lot of construction around where you drive, that might have something to do with it too.
Old May 14, 2003 | 11:58 AM
aznsap's Avatar
so when changin brakes, is it a better idea to leave the dust shield on? i think it looks kinda stupid, but if it serves a good purpose i might as well just leave it. also, if im changing my brake lines, do i completely replace all my brake fluid or jus replace what is lost? thanks.
Old May 14, 2003 | 12:18 PM
StygianMax's Avatar
I don't know all the pros/cons to removing the shield. If cooling is a big issue for you, removing the dust shield will allow the back side of the rotor to cool slightly quicker. But then again, if braking is particularly important to you, you'd be better off getting good pads.
No experience myself in flushing/bleeding brake lines. Here's what some other guys have recommended: quantity of fluid req'd Hope this helps ya.
Old May 14, 2003 | 12:23 PM
sbslacker's Avatar
Cut that shield off with sheet metal cutters. No need for it.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
