Water spots on sunroof how to get them off
May 14, 2003 | 08:03 AM
i have a lot of water spots on my sunroof and it really bugs me, is it possible to remove them? is there a good spray product for this? thanks for any help..
May 14, 2003 | 09:58 AM
anyone? please i really wana know
May 14, 2003 | 10:07 AM
Try washing your car. and then drying the sunroof.
May 14, 2003 | 10:08 AM
Quote:
wow thanks for that excellent answer, i just got the car, and it already had water spots, i just washed it the other day, and no it didnt come out, so can i please get a better response than one from some moron, please?
May 14, 2003 | 10:11 AM
*******, try windex, or alcohol. and drying the glass should work, unless it's not from water, idiot.
May 14, 2003 | 10:19 AM
Woe, calm down boys. Make sure the spots are on the outside. If nothing you use works. You can always use brake cleaner. Put some on a cloth and rub. It takes out anything! I used this on my glass before putting on a window decal. It worked really well. I would only do this as a last resort. Keep brake cleaner away from paint!!!!
I'd try regular window cleaners first though.
May 14, 2003 | 10:27 AM
Quote:
Originally posted by ZuMBLe
Woe, calm down boys. Make sure the spots are on the outside. If nothing you use works. You can always use brake cleaner. Put some on a cloth and rub. It takes out anything! I used this on my glass before putting on a window decal. It worked really well. I would only do this as a last resort. Keep brake cleaner away from pant!!!!
thanks for the help, all i wanted was a quick response not some stupid a$$ crap from a newb, thanks
May 14, 2003 | 10:31 AM
Quote:
A newb........ok, I gave you a quick answer you didn't say you had tried to wash it so I went with the simplest thing first. Some people (you) are just ungrateful A$$holes.
May 14, 2003 | 01:11 PM
try any type of mild detergent and dont forget to wipe off any of the excess water!!!
May 14, 2003 | 01:47 PM
Did you even try cleaning it before you asked?
May 14, 2003 | 02:02 PM
See this thread......
http://forums.maxima.org/showthread.php?threadid=215429
The same process worked great on my moonroof.
May 14, 2003 | 02:06 PM
Geez, a newb...obviously from the tag line under his name he isn't a newb...he gave the most logical first try answer...looks like maybe you are the moron
May 14, 2003 | 02:19 PM
Clearly, neither of them are newbs. So, it should have been assumed that the most logical solutions had already been tried.
Gently rub some 0 grade steel wool over the glass. Someone here recommended it once for cleaning the windows and I've done it with pretty good results. If you get 0 (really fine stuff) then it won't scratch the glass (but try it in a tiny corner jsut to make sure). And, of course, don't try it on the inside of the glass if there's any tint present (I forget if the inside of the sunroof is tinted).
May 14, 2003 | 02:20 PM
1. The guy was trying to help, why don't you not be an *******, ad just accept that he was trying. You weren't clear on what you did, and he gave the best answer. D1ck.
2. Try not washing the car in the sun. I've had that happen to me before, but only when i washed the car and the sun was drying it before i could chamois it off.
3. Try an industrial film cleaner. You can find stuff like that in places that specialize in printing and arts supplies. the stuff that i use will take anything off your windows. As a matter of fact, i have to reapply the Rain-X after i use it, because it strips the rain-x right off the windows.
May 14, 2003 | 03:26 PM
A few years ago I bought some window cleaner that was basically a buffing compound made for windows. The paste is blue in color and was in a black and white tube (if I remember correctly). I suppose a little Megauirs Paint Scrub or some other type auto body polish would do the same job. Good luck!
May 14, 2003 | 04:12 PM
try a vinegar and water solution, like 1/3 ratio vinegar to water.
May 15, 2003 | 11:35 AM
Re: Water spots on sunroof? how do i get them off?
The guy on Motorweek recommended using Bon Ami cleanser and super fine grade (0000)steel wool followed by hosing it off with water to get all the crud off on windshields. I'm sure it would work fine as long as it's a glass surface.
May 15, 2003 | 11:52 AM
Re: Re: Water spots on sunroof? how do i get them off?
I used to use Bon Ami instead of the plastic polish but it was a pain to rinse off and would leave residue all over the rest of the car. That's why I switched to plastic polish. Bon Ami is way cheap, though.
