problem with idle after VI installation
Old May 14, 2003 | 10:16 PM
CalsonicSE's Avatar
After recently installing my VI (I changed all the gaskets including the IACV), with the transmission in D and at a complete stop, half the time the car idles normally at ~650rpm, but other half of the time, the car will idle at 1000 rpm. It's weird because at one stoplight the car might idle normally but at the very next stoplight, the car might idle at 1000rpm. I don't think it's leak because otherwise the car would always idle at 1000rpm or idle would fluctuate up and down. What gives?
Old May 14, 2003 | 11:16 PM
Shoooter_j's Avatar
I've actually noticed this too, and have yet to install my VI
Old May 14, 2003 | 11:24 PM
xHypex's Avatar
I've never had that. Once I had a leak so the idle would fluctuate up and down at idle, but I can't think of any reason it would idle high and stay there.
-hype
Old May 15, 2003 | 12:09 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
hahah good answer.......
Old May 15, 2003 | 06:59 AM
Keven97SE
Check the calibration of the TPS, throttle position sensor. If it the cal is above spec, the ECU may think the throttle is open and use a fuel/ignition setting other than the idle routine. With the throttle closed, the value should be between 0.35-0.65V, I believe.
Before you do this, you should also clean the throttle body. It may actually be slightly open due to carbon buildup. Perform this before you check the voltages/calibrate.
Old May 15, 2003 | 10:06 AM
XXXL Cracker's Avatar
I had extreme fluctuations with my idle after the install. My problems were vacuum related.
I would definitely check the TPS.
D
Old May 15, 2003 | 11:35 AM
KMax2988's Avatar
I've been having fluctuations after my install and still have not been able to find the source. Usually, when my car is ideling it will drop to below normal (500 rpm) and either idle rough or idle fine for a few seconds. This still baffles me to this day. Checked everything I could, set the TPS and base idle a ton of times, and even replaced the IAC. Nothing helped. The funny thing is the car will seem to run rougher when dropping idle when it's not warmed up to normal operating temps. Even the techs at my work (Nissan Dealer) don't have a clue what is wrong. Oh well, guess I'll just turn up the boost and wait for something to explode now.
Old May 15, 2003 | 11:36 AM
KMax2988's Avatar
Oh yeah, it's been doing this since before the SC install also (prolly goin on for almost 6 months).
Cotozic
Jun 28, 2017 08:01 PM
Finkle
Sep 27, 2015 09:53 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Maxboy23
Aug 11, 2015 11:59 AM
kirkhilles
Aug 8, 2015 10:53 AM
