Brake squeak
Old May 15, 2003 | 07:49 PM
crashmanmike's Avatar
Brake squeak
I'm a novice do-it-yourselfer. Just changed brakes pads for the first time ever. Now I have a very loud squeel from the right side of the car on my 96 Maxima.
I used Raybestos pads from Pep boys and replaced all four pads on my car. The car stops normally and doesn't pull to either direction.
Did I re-install anything wrong? I thought I did a pretty good job. The Haynes manual does recommend an anti-squeel gel be applied, which I did not use. Could that truely be the culprit? No one I know has ever used it on any of the brake changes they have done on their cars.
Thanks for the advice all.
Mike
Old May 15, 2003 | 09:57 PM
taggate's Avatar
change my rear brakes with raybestos too, had a loud squeel when i reverse. but after i got the brake kit from the dealer cost me $22 appeal the brown and orange gel in the brake. the loud squeel stopped.
the brake kit that i bought also came with shimmys and other stuff if you want the product number here it is:
Hardware Kit-RE 44080-54c29
hope this gives you a hint.
Old May 15, 2003 | 09:58 PM
JPMax's Avatar
What's next!?..
If you used the self-adhesive shims that came with the brake pads, you don't need the anti-squeel gel.
Did you clean and regrease the pins on the caliper?
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
