headlight removal
headlight removal
hey does anyone have a step by step instructions on how to remove the head light in a 97...i would fool around but i dont wanna break anything, i have decided i need to clean the inside of the passenger side light..thanks guys!
Re: headlight removal
2. Remove Clearance Light by taking out screw on top and pulling light out.
3. Remove grill by twisting screw driver in both ends of grill
4. Remove 2 screws on side of headlight assembly that were exposed after clearance light removal.
5. Remove 2 screws on back of headlight.
6. Un hook the bulbs and pull headlight out.
I use a 3½ inch extension bar to remove top nut behind headlight. The flexy angle corner attachment on the end of my extension bar mounted atop a 10mm socket works just fine for the lower nut (drivers side). The passenger side is a little tricky, I remove the bottom one by the 'extension with flexy thing' just till loose, then I must finish bottom bolt by hand. The top, with a longer extension 6" i think. I take my headlamp housings out frequently.
Put grease on the nubs on the back of the side marker housings to make re-installation and removal much much easier.
My 2¢
(_8*(l)
My 2¢
(_8*(l)
doctorpullit
10-28-2019 10:58 PM
trsandrew
04-08-2016 06:45 PM
knight_yyz
11-01-2015 01:34 PM
