What Happens When A Car Misfire
Old May 17, 2003 | 02:06 AM
Reaction21's Avatar
I was reading some of the forums that other members have posted up and one of them have a very similar problem that i was having right now my car would sometime start up and the RPM would go crazy from 500-1500 really quick up and down up and down like someone is pressing on the gas while the car is on Neutral cause i have an 5 speed is that what a misfire would do and what do i need to do to slove the problem Thanks for any help that is given
Old May 17, 2003 | 04:51 AM
96SE5Spd's Avatar
Re: What Happens When A Car Misfire
A misfire is when one of your sparkplugs doesn't light the mixture in one of your cylinders, this can be caused by a number of things. Whats happening in your car probably has something to do with your IAC.
Old May 17, 2003 | 04:55 AM
Ninos_Maxima's Avatar
be the change u want2C
Re: Re: What Happens When A Car Misfire
Please tell me what those number of things are, My car is having the same problem
Old May 17, 2003 | 05:05 AM
96SE5Spd's Avatar
Re: Re: Re: What Happens When A Car Misfire
Fouled spark plug, bad coil pack.
Old May 17, 2003 | 07:04 AM
95CustomMaxima's Avatar
bad fuel injector too. Symptoms: The car shakes real bad at idle...you can feel the steering wheel + shifter shakings, performance is also gone, studders during acceleration.
-Nick
Old May 17, 2003 | 05:10 PM
Peter_98_SE's Avatar
Hey Guys,
I know that this is one of the most major and hardest to solve problems with the Maximas. I already know 6 people from here (including me is 7) that have the same kind of starting problem, and can't seem to fix it. The symptoms are almost always the same: RPM's shifting anywhere between 500 and 1500, car shaking violently, and then stalling. I have heard Nissan and other people here say that the possible causes could be faulty or dirty injectors, IACV (idle air control valve), PCV valve, dirty throttle body, spark plugs, a bad ground, old fuel filter, etc.... The list just keeps going on and on. From what I know, people are just sick and tired of replacing these things and finding that the problem still hasn't been eliminated. I just wish Nissan or somebody did an investigation as to what the real problem is, and not have more people spend their money. But does anyone finally know what the REAL cause is without having any more people guess?
Old May 17, 2003 | 05:49 PM
charliemax's Avatar
i ran into the same problem about 4 years ago. i took it to the dealers several times before finding out the problem (they've cleaned the TB and injectors but didn't help). the problem i had was with the throttle body positioning sensor. after it was replaced, it never happened again. so check it out.
Old May 17, 2003 | 11:27 PM
Reaction21's Avatar
Thanks for all the Help Provided Guys
Old May 18, 2003 | 03:36 AM
MistaPeerez's Avatar
how much would a throttle body positioning sensor cost? oh by the way im number 8
Old May 18, 2003 | 05:21 AM
Mishmosh's Avatar
So all this is happening and your car is not throwing any codes?
Never had the rpm problems, but recently my car was misfiring and once driven for a while a cylinder misfire turned up. I eventually replaced the coil pack and smoothness and power were restored.
Old May 18, 2003 | 07:07 AM
RichMax's Avatar
Boosted like Snipes tax refund
That's the code my car has been throwing: 0403-throttle position sensor. It's a stored code, so without checking, I might never have found it. Sounds like a strong suspect...
Old May 19, 2003 | 01:05 AM
Reaction21's Avatar
keep up the good work with the info guys too many people here are having this problem it would be nice if this problem was slove it is a pain in the *** to have this problem
Old May 20, 2003 | 12:29 AM
Reaction21's Avatar
Old May 20, 2003 | 06:13 AM
Spectre's Avatar
Alright I've been having the same problem as stated for a couple weeks now and yesterday I've changed the sparkplugs, cleaned the throttle body, and got a new air filter. Still the same problem and today I am going to check out the throttle positioning sensor, tho I did take the green machine to the nissan dealer and talked with the mechanic and he told me it might be the throttle sensor and an idle starter or something. I will work on both today and report back if the problem goes away.
Old May 20, 2003 | 08:39 AM
SonicDust187's Avatar
My car has been having weird idle, one moment its 600 then 750. It may go up and down a little within that range. When I listen to my intake when the car is idling, it sounds like hickups, almost like a drum roll. What do you guys think may be the problem?
Old May 20, 2003 | 09:46 AM
how much would it cost to replace bad ignition coils, throttle body postion sensor, and the Fuel Filter?
Old May 20, 2003 | 07:36 PM
Also will my Bumper to Bumper warranty cover the sensors and the ignition coils?
Old May 20, 2003 | 08:27 PM
ghetto_bill's Avatar
I'm having a similar problem, but it's just starting. When I start the car the idle goes to like 1000-1500rpm then drops down, almost stalls, well sounds like it, then it goes back to normal idle. I'll make sure I put this thread in my favorites. It's great to have all this positive feedback.
Old May 21, 2003 | 06:04 AM
Spectre's Avatar
A throttle sensor is 60-70 bucks, fuel filter shouldn't cost you more than 15 bucks and iginition coils are I think around $100. Heres a good site to get some info from.
http://www.nissanpartstore.com/Nissan_Maxima_16015.html
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
yat70458
Aug 3, 2015 01:16 PM
